at 30mph loud humm from front tires?
On my 06 Cobalt when I get arond 30mph starts sounding like I'm in low gear you can only hear it with windows up the sound stays till I slow below 30mph or I take a left hand curve I have 205/55R16 91
belt shifted?
no started doing it with old tires so I got new ones still the same
Originally Posted by Rcash
(Post 5850076)
If you kind of weave left / right /left / right, does the noise come and go? |
this^
aka wheel bearing. just did my friends civic, exact same thing it hummed was so annoying. got a new one, install was simple and cant hear a thing now. if you dont feel comfortable just take it to a shop it shouldnt be more than 200 |
it only goes away when I make a wide left turn and I had a friend drive past me and I did not hear it outside there is no shimmy I can take my hands off steering weel still goes strate
Well it's easy enough to test. Jack it up, grab the tire at 12 and 6 and see if you feel any play when you push and pull.
Originally Posted by DaBuzzard
(Post 5850382)
Hub bearing is my bet.
Just tested and replaced wheel bearings but noise hasn't stopped
I have been hearing the same noise. It gets louder when turning to the right and goes away when you turn to the left while driving. Naturally I figured it was a wheel bearing. I put the car on the lift and had some play in the passenger wheel. So I just replaced the bearing today and that wasn't it. The noise is a little quieter now but still present. Now I'm thinking its the bearings on the case of the tranny where the axle comes out. I started the car on the lift and heard exactly where it was coming from. Now what I don't know is how to even begin getting to those casings. Do I have to pull the whole dam axle out?!? I also tried to check the U-joints and when I removed the ring of the U-joint boot, I began to loose some sort of grease/fluid, so I just put it back together. Does anyone know how to help? or has done this before? and doesanyone think i have to open the tranny to press those casings out. I have the part # for them. Please please please someone respond with any info. If i cant do it I'm having a shop do it, but **** Chevy. Last time my brakes had a leak they gave me the car back with a leak still.
Just as everyone else has said it's most likely a wheel bearing.
Yup front hub assembly....take it into the dealer it will be covered under powertrain warranty if your car is still under it
