All you clutchmaster guys out there..
Hey, just wanted to know anyone if there is any, with a clutchmaster stage 3 on their ss t/c, what does your pedal feel like? Where does it grab? Etc etc. Just had one installed and to me the pedal seems reeealll funky were gonna bleed it again tomorrow see if it changes anything but I just wanted to see how others feel. Thanks!
Probably still have air in the system
Mine feels great but i have the ZZP clutch rod |
I was thinking I might need that. How did it feel before the zzp rod?
I doubt u need the rod..vacuum bleed but also force feed the mastercylinder with a pressureized line the pushes the brake fluid out by using more fluid in a container. Gm uses a machine to do this. ... A+ way
Thanks alot!
Just installed stage 4 - 4 puck
rattle on idle.. increases with throttle goes away when clutch is pressed in rattle when slowing down -- cant tell when going faster gear has an extremely hard time going in 3rd or fourth sometimes when upshifting and even worse downshifting brand new throwout installed im pissed.. transmission was absolutely perfect before this clutch.. i read your other post.. i would be so happy if I just needed to bleed it more. |
There is a rattle when im coming down from 3rd 4th or 5th, like a down rev its louder if im coming down from a higher rpm and just let it coast down, it does pies me off but no rattle on cold starts or at idle which I am super happy about. You think your problems could be from your install? Maybe you didn't do something right?
Originally Posted by seeyaass
(Post 5764602)
Originally Posted by 09BaltSSTC
(Post 5765098)
Nah.. Nothing installed wrong. out of box failure throw out bearing..
bought it off a guy on here... FAIL
Ouch man. You fix the problem yet??
(Post 5770031)
