Custom Axles, boots and spindle nuts.
Old Oct 30, 2008 | 12:25 AM
40rty's Avatar
Alright, so I was doing some research to see if I could find anyone out there that makes aftermarket, stronger axles etc...
Well, these are some that I found.
http://www.fwdaxles.com/index.html
http://a1driveshaft.com/driveshaftFrameSet1.html
I was just wondering to see what they had out there and if anyone had the ability to make some aftermarket robust axles etc. What do you guys think? The tranny would be the only thing left that would be considered the weakest link if kits, tunes etc are added to your car.
Old Oct 30, 2008 | 12:35 AM
Sharkey's Avatar
driveshaftshop.com already makes axles for the cobalt. they are around $750 for the pair.
Old Oct 30, 2008 | 12:44 AM
40rty's Avatar
But are they stonger than stock one's?
Old Oct 30, 2008 | 12:50 AM
EXsoccer1921's Avatar
yes they are stronger
ACESSbalt's Avatar
yeah they are rated at 400 hp also called stg2 axles and they even make axles that handle 800 hp called stg5
Old Oct 30, 2008 | 12:51 AM
hydraze's Avatar
ofcourse, i thing its good for 450hp, i believe they got even beefier ones up to 800+.
Old Oct 30, 2008 | 01:06 AM
40rty's Avatar
This is great, so I'm guessing that the even if it says "For the 2.0L SC" the TC and the SC share the same axles, correct?
Old Oct 30, 2008 | 01:14 AM
no idea on that one. talk to hahn. he's worked on both cars
Old Oct 30, 2008 | 01:34 AM
40rty's Avatar
ok
according to http://en.wikipedia.org/wiki/Chevrolet_Cobalt_SS , seems like the SC from 05-07 used the F23 and it was made by GM in two different versions. Now, TTR does have a conversion for a 6 speed. So the axles are good, now its weather I could get a better transmission.
Old Oct 30, 2008 | 02:16 AM
Sharkey's Avatar
the ss/sc came with the saab built f35. its the same tranny used in the ss/tc, the only difference is the final drive ratio (4.05 for sc, 3.82 for tc). the f23 was behind the 2.2 and 2.4l.
the 6 speed kit has been discussed here and in general, its not really worth it. you add another gear, but all it really does is make the tranny a close ratio, you dont have a steeper overdrive so it doesnt help fuel economy. havent heard the holding capacity yet, no clue on how much stronger it really is.
Old Oct 30, 2008 | 02:24 AM
HunterKiller89's Avatar
whoever TTR gets the 6sp conversion from said its about 35% stronger. and yes, the STG II axles will fit on a SS TC....its the same tranny as the SS SC after all.
Old Oct 30, 2008 | 02:44 AM
Sharkey's Avatar
the kit that ttr sells is made by quaife. ive seen other sites with it listed
Old Oct 30, 2008 | 03:07 PM
ACESSbalt's Avatar
they are all about the same price
Old Oct 30, 2008 | 04:38 PM
40rty's Avatar
Any other tranny that has the same bolt pattern that I can install?
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
patooyee
Oct 15, 2015 05:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
