F35 tranny noise never answered...
Hey new to site. First time posting on a forum ever. Read many but never joined or posted. I have the same tranny whine everybody has mentioned but I've read through and no one answered. A lot of guesses and one guy rebuilt the whole tranny. I'm not doing that. So.... tranny whine when letting off throttle while in gear? Any REAL answers? A lot of people experienced this so either they fixed it and never shared the solution or there are a lot of you that still have this problem. 2009 SS sedan with 102k. Thanks |
100% normal
I've had it with all of my F35 cars. The LSD equipped cars are even more noticeable. |
Really? It sounds terrible. How can this be... does anyone at least know the source of the noise? It's been like 10+ years, I was hoping someone had this pegged. |
The Swedes like it loud
One of the bearings must be loud when it is loaded in reverse. |
I'm going to swap the fluid in hopes it quiets down. Any further information would be great |
Spoiler alert: it won't
The only thread I've read that got the sound to go away was a guy that did a total rebuild. Which means there is a specific thing that causes the noise and if replaced will eliminate. I've been researching hoping to find an answer. The only thing I've read that makes any sense is people replacing the intermediate shaft bearing, with no follow up on if it worked(which was posted in 2011). And also I read on a Saab sight that the preload on the output shaft from factory was slightly under torqued, and after various heat cycles the crush sleeve has a slight movement due to it heating at a different rate than the housing causing shaft play over time and creating the noise. I was hoping by now someone has it figured out and it wasn't one of those learn to live with it situations. Guess I will turn up my radio!! (Insert smiley face with hand gestures) |
yeah the F35 makes weird noises. my LNF was pretty quiet, my LSJ is stupid loud. no fucks given
My lnf trans was quiet. My lsj trans with 4.45 gears whines pretty good. I'm sure it's due to the gears and higher Bearing preload that he used.
If the sound isn't an indication of an imminent failure why worry about it?
In all other transmissions I've had this type of noise meant something was wrong |
I actually took mine back soon after I bought it because of the noise. They had it for at least two weeks waiting for parts. I got it back, still noisy. That was 100k and two fluid changes ago and it hasn't changed at all.
my trans has 169k on it and makes the noise. but no issues shifting and I've changed the fluid. didn't help
I test drove 3 different ss/tc one being non g85 and the other two(one being the one I purchased) had g85. All three had a whine, the worst being the sedan g85 I originally wanted to buy. It had I think 60kish miles. Mine was the least noisy but still whined with 39k when I purchased it. It shifted good when I bought it, even better when I changed the fluid but it still whines nearly all the time. As common as it is I wouldn't be to concerned about it. If you are just save up for a rebuild or get a spare.
Originally Posted by CJ_Lee
(Post 7683734)
It's a Cobalt. Don't expect perfection.
It's also a very good trans. Not many fwd trans could reliably hold the torque of a stock TC, let alone GMS1 at the time. You can't have it all especially in a $20k car. |
Hey I appreciate it. I couldn't get the fill plug loose anyways. I had to use a breaker bar just to loosen the oil plug. But I installed a shorty ZZP intercooler and changed oil and spark plugs. I have to say it rips!! I did notice a lot of torque steer. Even in like 3rd. I have lowering springs in the front so it naturally has camber. Not sure if I like that. But any one have this? It's almost dangerous. |
should be able to get the alignment back in spec without much issue. the torque steer is not normal for these car, you likely have worn out control arm bushings
What sharkey said- the rear control arm bushings will tear and allow to much movement. Spherical ones make a huge difference. I always suggest using Powell raceshop bushings but they aren't cheap. Have a lifetime warranty though. Mine has a lot of his suspension parts on it and has 370whp and I can drive it wide open throttle with 2 fingers.
Really? Good to hear. Is it cheaper just to get new control arms? I still want a slightly comfortable ride but I do want to be able to hug corners with confidence. My stock struts don't have camber adjustment. So any suggestions on struts? My strut braces are rust and it rattles over larger bumps so I need new ones. |
(Post 7683824)
Really? Good to hear. Is it cheaper just to get new control arms? I still want a slightly comfortable ride but I do want to be able to hug corners with confidence. My stock struts don't have camber adjustment. So any suggestions on struts? My strut braces are rust and it rattles over larger bumps so I need new ones. I would suggest doing a full refresh on your suspension if your funds allow it. New, factory FE5 struts/rear shocks, KYB strut mounts and the control arms. Will be the best money you've spent on the car to date. |
Thanks Tman. So I found the passenger side ball joint wasn't fully tightened and allowed a little play. So I tightened that up. Much better. Still seems like there is some play in the steering rack. Anyways. I'm currently sitting at my buddy's shop. Just got the tranny plugs loose and drained the fluid. I have the factory AC Delco fluid to put back in. My question is how much? All the threads say 1.7qts. Is that LSJ? Because my owners manual CLEARLY states 2qts for the 2.0 L4 engine and 1.7 for the 2.2 L4. I saw somewhere that a guy removed the reverse sensor and used that as a fill hole to get the full 2 quarts in. Just curious if anyone has a suggestion or input. I would like to put the full 2 in. |
fill it till its pouring out the fill hole. the volume they give you is what gm put in on a dry fill so its not accurate for servicing.
Well I have the driver side jacked up to put some angle on it. I called a gm dealer and stated the 888xxxx number for the fluid. He said there has been an update to the number. I said ok. So I'm adding it and it's not red like what came out. It's 10-4104 (19351859). It says it is manual transmission fluid, GL-4(SAE 75w-85) high performance gear oil. I will see how much fits. I lowered the driver side when draining so that the front left corner was the lowest point. |
Pretty sure you want the car level.
