GMPP clutch vs stock LNF clutch. What are the differences?
Old 12-10-2013, 07:47 AM
  #76
Powell Race Parts's Avatar
crate engine depot lsj
Old 01-04-2014, 02:57 AM
  #77
LNFwagonSS's Avatar
Gmpp clutch in HHR
I have a 2010 HHR SS with about 19k miles. I'm trifecta tuned and my clutch slips in 2nd at the strip. I am second owner and I believe clutch may not have been broken in properly from day 1. Ill admit I have slipped the clutch too much a few times enough to where I could "smell" it. Gonna upgrade the clutch so I can start adding more power/tq. So i have a few question and hopefully you guys can help me out:
1: with the HHR FDR different from cobalts, am I susceptible to more clutch wear?
2: the current clutch may be partially glazed and flywheel may be burnt? Should I get a new lnf flywheel from ZZP before I attempt to install the gmpp clutch?
3: should I buy the Cobalt Clutch Pipe part# 24422067 and/or the Ecotec clutch pilot tool part# 14534?
New clutch is on my winter mod list and I'm gonna slap this bitch in there soon so any advise would be helpful and appreciated.
Old 01-04-2014, 09:01 AM
  #78
buy an lsj flywheel whereever its cheapest, internchangeable with LNF DONT worry about internet wisdom on differences; clutch pipe is good idea; you will need flywheel bolts. clutch disc alignment tool is an essential tool for the job. Crate engine depot .com sell LNF clutch kits with prices at GMPP levels. good luck
Old 01-04-2014, 09:27 AM
  #79
So there's no difference in oem LSJ / LNF flywheels?
Old 01-10-2014, 03:28 AM
  #80
Dart_SI's Avatar
theyre the same pretty much.
Old 01-13-2014, 12:26 AM
  #81
LNFwagonSS's Avatar
You think it would be a better idea to buy a new flywheel rather than resurfacing the old one?
Old 01-17-2014, 12:56 AM
  #82
kennyjames's Avatar
Arrow
The GM performance upgrade clutch for the LSJ, is an LNF clutch. The TOB with the upgrade or from the LNF is an upgrade from the LSJ as well.
Old 01-17-2014, 04:29 AM
  #83
tuned08ss's Avatar
Wrong
Old 01-17-2014, 08:53 AM
  #84
^^^ what is wrong with this statement, its pretty darn close . The pressure plate is 100% the same, the clutch disc has different lining and a slightly different spring pack in the center section of the friction disc, the TOB is 100% LNF.
Not sure what the issues here are, we keep going back and forth , there are numerous threads on it, and both Tom@ced and I have stock on the shelf to compare. FURTHER, Tom has put an LNF kit together priced as close to GMPP as possible with the same parts as GMPP as GM dont do packages like that much
hope this helps. Not sure what folks do. Maybe dont read the thread? I have repeated this info numerous times. ugh
Old 02-10-2014, 03:52 PM
  #85
AyOh13SS's Avatar
So, if what I'm reading means what I think it does, my 09 LNF with GMS1, Injen Upper Charge Pipe and CAI, ZZP catless DP and soon to be ZFR with a tune to (an educated guess from others with more experience than I) 375-400whp/400-450wtq will be fine if I get the GMPP clutch kit? My stock clutch will eat itself from what I understand.
My 2 main concerns are;
If I get a clutch, i.e. KY S3 or 4 or SouthBend S4, and then my transmission implodes on itself.
I get a GMPP and it slips and dies because it can't handle the power being put down.
If the GMPP can handle all of that, I'd much rather stick with that because I had it in my LSJ which, while stock, I loved that clutch. The feel and everything was comfortable to me with the way I drive. I'd rather not spend a bunch of extra money for no reason on a pricey clutch when the GMPP will do just fine. (I work for GM at a Chevy dealer. Cheap parts. )
Old 02-10-2014, 04:00 PM
  #86
taintedred07's Avatar
Save your trans, do the gmpp
Old 02-10-2014, 06:30 PM
  #87
I'm kinda in the same spot as you. I'm going to be getting an HP tune this spring and eventually want to get a bigger turbo. I planned on getting a Southbend Stage 4, but I really think I'm going to just go with GMPP for now since it'll be easier on the tranny.
Old 02-10-2014, 06:45 PM
  #88
good plan. + driver mod. Let the pressure plate clamp before you hammer down. The tenth you spend doing that is not going to lose your race in 1320 at this stage in your life.
Old 02-10-2014, 07:03 PM
  #89
Yes, driver mod. I don't want to shatter any gears into a million pieces lol
Old 02-10-2014, 08:32 PM
  #90
BUT I have had 3rd gear break under load at peak torque in an LNF mod'd car. May have been previously weakend ( hop,launches,etc) but at the time.? BAM crunch crunch crunch groan ( groan was me)
Old 02-10-2014, 08:46 PM
  #91
At least when that happens one gets to hopefully upgrade to a 4.45 if available.
Old 02-10-2014, 08:58 PM
  #92
may have to chose 4.05. 4.45 are getting really hard to find
Old 02-10-2014, 09:03 PM
  #93
That's what I hear, unfortunately.
Old 02-18-2014, 04:54 PM
  #94
tuned08ss's Avatar
So the oem gm 2.0 flywheel for sale at zzp fits the lnf? Asking because some say the lsj and lnf flywheel are different
Old 02-18-2014, 05:11 PM
  #95
LNFTX's Avatar
^This again???
psst. LSJ and LNF flywheels are the same. some LNF have larger diameter cover guide pins. not all.
price difference is HORRENDOUS.
Go to CED buy GMPP and LSJ flywheel . win.
This quote is from THIS thread
Old 02-18-2014, 05:38 PM
  #96
Originally Posted by LNFTX
^This again???
Reading is to difficult
Old 06-27-2014, 01:35 AM
  #97
wol-shiver's Avatar
John, looking at ced your comment confuses me. The lnf clutch kit is all stock and does not contain the upgraded disc....
Old 06-27-2014, 03:54 AM
  #98
footballplaya3k's Avatar
Facepalm. Just get the CED LSJ clutch upgrade kit AKA GMPP clutch.
Old 07-20-2014, 11:07 PM
  #99
RBC
RBC's Avatar
I am considering doing the "gmpp" clutch kit but after looking on CED's site there are a few things that confuse me. I will start with some info on my car.
Its a 60k mile 2009 SS Sedan w/ trifecta 25 psi tune, catless downpipe, and charge pipes. The clutch holds great on the stock tune but slips a bit with the tune on. I am wanting to run e85 so I will for sure need a new clutch. In the future I most likely will be doing a turbo upgrade but not sure how long. I would like to do the ZFR but i'm not sure when they will be available again from ZZP.
Here is what is confuses me. It specifically says do not use on an LNF. Is this just legal mumbo? I see they do however sell the stock LNF clutch aswell. Is there any proof that one is better than the other?
Also, Can I resurface my stock flywheel? It says that manual trans flywheels must not be machined. I have machined, balance, and lightened many stock manual trans flywheels with out a problem in the past. Can the stock flywheel bolts be reused?
Old 07-21-2014, 08:05 AM
  #100
If you want warranty the clutch will have to be installed by a GM dealer. If it gives issues , and a dealer installed it, the dealer will look at the part numbers. Notwithstanding the sense of the part number interchangeability in fact, the correct part number referenced to the correct car VIN is required if there is to be any consideration for warranty.
Therefore, LNF part for LNF.
Stock flywheel bolts are TTY> reuse at your risk. I would not reuse old bolts.
Flywheels can be scuffed with 80 grit, or machined so long as the step is machined as well. Given the cost of machining, a new flywheel is a sensible alternative.
Quick Reply: GMPP clutch vs stock LNF clutch. What are the differences?
