Help! no clutch relese at high rpm?!
Old Aug 5, 2010 | 06:07 PM
Kustom06SS's Avatar
About 9 months ago I put a Clutchmasters stage 4 in my 06 ss/sc. a few weeks ago i had it tached up went for fourth gear and couldnt get it.. or any others. the pedal didnt go soft it was still firm but even on the floor it wont disengage the disc. after maybe a minute or two it works fine again. this only happens above 4500 and in any gear. after i get on it i have about one shift and then this happens. I have no problems with it any other time. I can go first to reverse no prob. Bled clutch repeatedly with no effect. slave/relese was new with clutch kit. Anynone had this problem or a soloution. Best I can figure is the clutch master isnt strong enough for clutch? Thanks
Old Aug 5, 2010 | 08:12 PM
Iam Broke's Avatar
I had the same issue with the install of my SPEC Stage2+ & LW flywheel. The clutch was dragging a bit. Vacuum bleed the clutch several times and if it still persists, (like mine did) install a ZZP adjustable clutch rod. It'll raise the pedal a bit and give you a pinch more throw. It ain't easy to swap the clutch rod though, I'll warn you.
Hopefully you installed the upgraded (LNF) slave cyl when the clutch was done, if not I don't think the rod will help.
Old Aug 6, 2010 | 09:52 AM
Kustom06SS's Avatar
thanks for the info. i figured this had to have happened to somone else. the slave came with the clutch kit so i would have to assume it is strong enough. do you have to take the master out to install the rod? and where did ypu come acrss the part?
Old Aug 6, 2010 | 11:37 AM
Iam Broke's Avatar
Yes, the part is difficult to change, the clutch master cyl. has to be unlocked from the firewall to change the rod.
I have a thread from when I did mine...
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/zzp-clutch-rod-install-help-please-208059/
Here's the rod...
https://www.zzperformance.com/cobalt...1096&catid=187
Old Aug 7, 2010 | 04:58 PM
Kustom06SS's Avatar
Thanks for the info and the web guide. I find it funny that the zzp website says "30 min install" Theres no way. AllData calls for almost 2 hours to just take the master out and put it back. Oh well. Im in repair not sales. Thanks again.
Old Aug 7, 2010 | 05:31 PM
mmcgee123's Avatar
if u kno what ur doin it really only takes 30 min we put a whole new master and pedal assembly in two hrs just be carefull dont break the pedal when ur pulling the rod out
Old Aug 8, 2010 | 11:58 PM
Kustom06SS's Avatar
my luck ill break the pedal lol thanks for the advise tho. as soon as i can aquire a benjamen ill be ordering one. guess ill have to drive like a grandma till then
Old Aug 9, 2010 | 12:03 AM
thesteed46's Avatar
ZZP adjustable clutch rod = answer.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
SSLOW06
Oct 1, 2015 07:21 PM
Slick_Nick
Sep 28, 2015 09:15 PM
