ky stage 3 +1 slave bearing 0
Hey guys I just installed my stage three six puck ky clutch and new tob and everything seem to be going fine until about 70 miles in I started losing clutch pressure then I fully lost it and it was just stuck at the bottom so I brought it back to my mechanic this morning after driving it like a goon, tryd rebleeding it tryd vacumm bleeding it and got no where except I noticed there was oil on the bottom of the bell housing is there anyone that can point me in a direction with this I'm pretty bummed so anything will help,
Also when we were vacumm bleeding it it felt like it kept sucking up a lot of air not sure if that means anything or not but oh well
Thanks sebastien
Thanks sebastien
Either 1) the clutch pipe wasn't secured to the tob bearing correctly and it's leaking in the bell housing, 2) the tob is bad out of the box and it's leaking fluid or 3) the black plastic nipple on top of the clutch pipe that meets with the clutch pipe elbow (distribution block) wasn't placed back on the pipe before the elbow was clipped back on the pipe.
It more than likely #1 or #3, but 3 is the easiest one to miss.
yea hes a liscenced gm tech as well so i am suprised as well, i will check both these things out on my own then if not i will bring it to the big guys of gm canada ! lol not theres so legit shops out here just they charge out the ass ahah ! more input will help tho ! thx guys
DANRICKARD
10-01-2015 12:08 AM
