LNF Tranny on LSJ?
Has anybody swapped out the LSJ transmission for a LNF transmission? I know the gears are wider, and I'm wondering if that helps with traction in 1st and second, and also wondering if it would work well in the long run.
why? 4.05 is way cooler. depends on the application but if you're gonna get into it that much might as well say screw a stock gearbox.
Yes, they're interchangeable. It's a matter of personal preference. I'd rather have the 4.45 final drive from the Grand-Am Cup cars.
i would not want that trans with the stock blower. the gears are much wider and it's going to fall out of power band.
hai josh
The transmission I want is the ZZP stage 2 transmission with the 4.45 FD
agreed
You're all nuts, I want a 3.42 gearset! lol.
Yeah what's done to your car?
Loving my 4.45 Final Drive
(Post 5727478)
Only difference is the final drive... and we need all the gear we can get. Tires and suspension moss are where you'll see the traction increase..
It's not stronger. It's the exact same trans, just a different ratio final drive. Your car will be slower with it because of the final drive difference.
The gears are not wider, it's the same thing with a lower final drive ratio.
