LNF Trans help
Hey guys, so this happened to me while heading to work, I was in first gear getting on to the freeway when my gear just popped out. I pulled over to the side and i couldnt put my car into gear, any gears. So i turned off the car and that was the only way the gears go in when the car was off. Any help guys? Its my daily and i have about 172k on it. I have stage 4 southbend/findaza flywheel, new clutch master cylinder, TOB. All these parts were installed about 7 months ago. So everything is brand new.
Sounds like a clutch release issue. Is it leaking brake fluid underneath?
(Post 7710188)
Cables stretched? Or did you break a roll pin? Does it grind? I agree it could be an issue with engagement. Anyway the clutch or flywheel could have worn enough to not allow enough stroke for the tob?
(Post 7710202)
Not to mention I bought all that stuff about 8 months ago
Did you ever figure it out? Sounds like something let loose in the clutch and is dragging
https://cimg6.ibsrv.net/gimg/www.cob...f7cf29595b.jpg
Originally Posted by C0balts5
(Post 7710729)
That should be warranty. 12 month 12k miles
(Post 7710905)
Im right there with you, I bought the exact same clutch 7 months ago after blowing apart 1 factory clutch, and 2 clutchmasters fx100. Bought the south bend one and used a factory flywheel. Saw so many good reviews on it and figured it would hold together better than the last 3 clutches but this makes me a lil worried. I don't launch or beat my car to death either, I am however full bolt ons and pushing 23 psi so that may have helped kill mine.
(Post 7710919)
I hope and pray to the car gods to cut me a break. Im thankful it's not my daily, took 7 months just to get 1200 miles on it
(Post 7710982)
As long as there is no blue spots, more than likely you will be ok, if there is blue hazing anywhere than your going to get clutch chatter because it's warped.
