Master Cylinder?
Old Sep 7, 2015 | 02:04 AM
calo247's Avatar
Master Cylinder?
so i was driving along today and i noticed that if i hit the brakes hard they work just fine but if i am going down a hill and slowly press on the brake pedal, the pedal will slowly go to the floor and i get little to no braking power.
i bled all the brakes using a vacuum bleeder and it did not help anything, this is leading me to think that my master cylinder is gone..... any body have any ideas? are the LSJ master cylinders rebuildable?
Old Sep 7, 2015 | 11:42 AM
I'm guessing you checked to see you have enough brake fluid right? How are your pads?
Old Sep 7, 2015 | 11:43 AM
I would just get a new master cylinder if that is the problem, but I'm not to sure if your able to rebuild one
Old Sep 7, 2015 | 12:07 PM
Sharkey's Avatar
did you run the system dry by chance? if you did there is likely air in the abs unit. to properly bleed it you need a scan tool that can put the abs is bleed mode.
Old Sep 8, 2015 | 12:28 AM
calo247's Avatar
yup fluid was full and pads are 75%
Old Sep 8, 2015 | 12:29 AM
calo247's Avatar
nope, was never ran dry
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
brett.higgins3
Sep 14, 2015 01:48 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
TurboWood
Sep 7, 2015 11:08 AM
