Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Drivetrain (https://www.cobaltss.net/forums/drivetrain-79/)
-   -   Poly Trans Mount Idea. (https://www.cobaltss.net/forums/drivetrain-79/poly-trans-mount-idea-43033/)
tricky1 Jan 9, 2007 01:07 PM
This applies to the LS/LT cobalts. The Intense inserts do not fit in the stock 2.2 mounts. However the Cavaliers appear to use almost identical mounts to the Cobalt. This is mainly because the 95-99 Cav's used a Isuzu Transmission and the 00-05 Used the Getrag F23, the exact same as the Cobalts.
This brings me to my point, It is possible that the Cavalier Inserts will work for the 2.2 guys. If you look at this page with the inserts on TTR the front mount looks very similar to the Cobalts, in fact the Cobalt front mount says "CAV.2" on it.
http://www.turbotechracing.com/produ...idcategory=709
Thoughts?
TurboTechRacing Jan 9, 2007 02:13 PM
If someone will measure the width of the casting and the diameter of the hole. We will know if GM used the same size, if not we WILL make these if we see an interest.
halfj99 Jan 9, 2007 02:19 PM
i can almost promis these will be the same
TurboTechRacing Jan 9, 2007 02:22 PM
This is what we are thinking, and if this is the case, we have the perfect item for every 5 speed 2.2 owner on this site :)
Prothane have holes in them, and they still have A LOT of play. Ours, Turbo Tech Racing, are 100% solid, and available in red, black, and blue.
If someone can get the dimensions mentoned above we can verfy the fitment.
halfj99 Jan 9, 2007 02:29 PM
http://img166.imageshack.us/img166/3776/4961wo0.jpg
the parts in red are the mesurments needed?
cawpin Jan 9, 2007 02:40 PM
If it isn't here by the time I get home tonight I'll measure my stock mount and post back here.
TurboTechRacing Jan 9, 2007 02:40 PM
Actually we need 4 measurements to start:
1. the large red circle, the outside of the bushing diameter
2. the inside diameter of the bushing where the sleeve pushes into
3. the inside diameter of the bushing
4. the width of the casting that the bushing goes into
tricky1 Jan 9, 2007 02:45 PM
https://www.cobaltss.net/forums/show...t=39884&page=2 Post #22 has the approx diameter as measured by me with a tape measure a while back.
TurboTechRacing Jan 9, 2007 02:48 PM
https://www.cobaltss.net/forums/atta...1&d=1168372060
Here is the basic starting measurements...
TurboTechRacing Jan 9, 2007 02:51 PM
Dim 1 on the cavalier bushings is about 3.5" in diameter...
halfj99 Jan 9, 2007 02:55 PM
that would be awesome...id do it but my jack is at my parents which is a 30min trip. and its 25 degrees and windy lol
tricky1 Jan 9, 2007 03:03 PM
1. Bushing OD: 4"
2. ID of Mount: ~3.75"
3. ID of Bushing: ~3.75"
4. Width of Casting: 2"
tricky1 Jan 9, 2007 03:04 PM
Those measurements all came from the bushing. I had an extra bushing that I measured.
TurboTechRacing Jan 9, 2007 03:23 PM
Originally Posted by tricky1 (Post 735451)
1. Bushing OD: 4"
The bushing OD is 4" and the casting ID is 3.75" how does this work? lol
Also #3 you say 3.75" ID of bushing... this should be .75-1.5" we are guessing...
tricky1 Jan 9, 2007 03:38 PM
The Casting ID would be 4" with a lip inside going down to ~3.75"
tricky1 Jan 9, 2007 03:39 PM
OK I figured out what you meant...the ID of the bushing is ~.75"
TurboTechRacing Jan 9, 2007 03:41 PM
The outside of the bushing (OD)
The inside hole diameter of the aluminum sleeve (ID)
The width of the rubber bushing
The length of the aluminum sleeve.
What trans is that from 2.0 or 2.2L
TurboTechRacing Jan 9, 2007 03:43 PM
You have a side view of the bushing?
tricky1 Jan 9, 2007 03:47 PM
2.2L Getrag F23
Both pics:
https://img260.imageshack.us/img260/...07smallee2.jpg
https://img413.imageshack.us/img413/...08smallgf5.jpg
tricky1 Jan 9, 2007 03:52 PM
OK for DIM 4 it's 2.75"
DIM1: 4"
DIM2: .75"
DIM3: Min 3.75" Max 4"
DIM4: 2.75"
TurboTechRacing Jan 9, 2007 04:00 PM
Anyone have a set you could send us, front and rear (brakets and bushings complete), you will get a new set of solid bushings for free. If interested email me @ Aaron@TurboTechRacing.com
tricky1 Jan 9, 2007 04:05 PM
I've sent mine to CobaltPerformanceParts...maybe Scott has the dimensions you need.
TurboTechRacing Jan 9, 2007 04:09 PM
Once we get a set in here, 2 weeks MAX and we will have them shipping.
tricky1 Jan 9, 2007 04:15 PM
If I could go without mine again I would.
