Problem with shifting into gear
Has anyone had a problem shifting into either second or third gear while they are accelerating rapidly and running anywhere from 5-7k rpms. I took the car to the track and when I tried to shift either into second or third gear under full boost as I go to shift into the next gear it feels as if there is something blocking me from shifting. The clutch is not the problem. My clutch engages perfect and there is no slippage. When I drive the car normal though and shift at a much lower rpm I can shift into any gear no problem. I guess the best way to explain this is as I am driving under full boost and I grab the shift knob and move it to the next gear it feels as if there is something under my shift boot like a plate or something that forces me to have to physically slam or wrench on it to get it to the next gear. I have no idea WTF it could be. Any ideas would be greatly appreciated.
What clutch do you have?
LNF TOB upgrade?
Sounds like your TOB is shitting the bed. Mine did exactly what yours did before it blow apart into 5 pieces.
Is your clutch pedal getting light under high revs to? When your under full boost and high revs pump the clutch pedal a few times and then see if it falls into gear.
LNF TOB upgrade?
LNF TOB upgrade?
LNF TOB upgrade?
Also the shifter bracket, friend had an lsj he couldnt shift quickly into third, turns out the bracket was snapped in half. Link for what I'm talking about GM ACDelco - Revised Shifter Bracket for LSJ #GM-55563732
