Rear Axle Replacement - need some assistance
I have a 2007 Cobalt LT with the 2.2, 4 lug axle. I am not sure if it has ABS and not sure how to find out. Aside from determining which axle to purchase, is there a How To to actually remove and replace one? I have tried to find one, but I can't seem to make any sense on how the forum is organized.
Thanks Robert https://cimg9.ibsrv.net/gimg/www.cob...f7b3c55575.jpg https://cimg0.ibsrv.net/gimg/www.cob...7140c37130.jpg https://cimg1.ibsrv.net/gimg/www.cob...677d20872a.jpg |
I suspect most all of the rear beams are identical, i feel like slowbalt would know the answer here.
Easiest way to find out if you have ABS: Look for a connector/wire coming from the wheel bearing. If you have that, you have ABS.
I can't tell with the pictures, but that positive camber on your tire I would check to see if the beam is cracked. If so, you need a replacement: Axle Assembly - GM (15232752) https://www.gmpartsdirect.com/oem-pa...w0LWdhcw%3D%3D Or do some junkyard digging. The part number is the same for all models, including SS, so I would say they are interchangeable. |
Originally Posted by ProfDNS
(Post 7702715)
Originally Posted by Blasirl
(Post 7702767)
It is most definitely bent if not cracked. My daughter spun out and slammed the rear drivers rim into the curb. I have found a 2005 26,000 mile 4lug with ABS for $150.00. Are there any parts I should be sure to ask be included?
The back of these things are stupid easy. I would replace all of these parts: the rear beam axel you can get from a junkyard obviously from a cobalt/g5 that does not have rear end damage. I would buy the wheel bearings/drums new -> https://www.rockauto.com/en/catalog/chevrolet,2007,cobalt,2.2l+l4,1433735,brake+&+whee l+hub,drum,1744, and; and 2 new shocks -> https://www.rockauto.com/en/catalog/...+absorber,7556 If you can get the rear beam cheap from a junkyard (ALWAYS NEGOTIATE), the other parts would only cost ~$100-$150. Remember, anything with brakes/suspension, you need to change out in pairs. |
This what I removed and replaced with my junkyard axle. I had to get new springs - wish I new sooner, I would have gotten Eibachs!
https://cimg8.ibsrv.net/gimg/www.cob...e595bc12b2.jpg This is where the impact occurred https://cimg9.ibsrv.net/gimg/www.cob...a79e27f222.jpg My daughter spun out in the snow and BAM https://cimg0.ibsrv.net/gimg/www.cob...a2b90a48f9.jpg This is the axle I removed https://cimg1.ibsrv.net/gimg/www.cob...38991bef05.jpg This is a closeup of the bend https://cimg2.ibsrv.net/gimg/www.cob...316e301b11.jpg I wish I knew the springs broke. You can tell they rotted away at the breaks |
