Shifting Issue
Well, my problem is when im in 3th gear and i want to shift the 4th gear around 5900 rpm or higher i can't engage the next gear because it's make a kind of wall that don't allow me to pass the 4th gear ,but if i hit the cut off in 1-2-3 for example it doesn't make it, but only on 4th gear and i don't know for the 5th gear because once the 4th is block i can't pass any gear until i slow down.
So what can be my problem. master cylinder? |
LSJ? Slave cylinder (throw out bearing as'sy) getting weak would be my guess. Not disengaging the clutch far enough.
LNF? Aftermarket clutch that needs the ZZP adjustable rod. |
Originally Posted by Iam Broke
(Post 5256296)
LNF? Aftermarket clutch that needs the ZZP adjustable rod. Thanks |
I have the same problem this started to happen after I installed the OTTP stage 2 kit.
sub'd for more info.. I am currently on the stock clutch set up.. |
bent clutch rod? u can look by ur clutch pedal to see if it looks straight or bent....if bent replace with this. get the master cylinder as well dont be cheap! when did a pull threw first to 2nd, 2nd wouldnt let engage. so i bought this and it shifts good now. my rod wasnt bent but i dont think the clutch was engaged all the way. something to check into :)
Cobalt & Ion ---> ZZ Performance |
i'm sure it's not the rod because i have the stock clutch and samething for blue.
Me i think it's the master cylinder or the throwout bearing of the clutch |
| All times are GMT -4. The time now is 08:48 AM. |
