Spanky's Monkey |
04-19-2011 10:49 PM |
SMG Built Race Trans & 06' TCM don't mix
I brought the last SMG Motoring 4T45E race trans for their old cavy project. The trans was installed on my 2006 LT and should have been a plug in play swap.
Well the trans works, however the stock TCM fails to electronically control the transmission. I thought there was a fault with the TCM so I had my buddy Mike drive over to my house with his 2009 G5 auto and we swapped his TCM for mine and it worked where as my stock TCM would not work at all. This was about 3 weeks ago. Since then I brought a new 2006 LT TCM and installed it last weekend. I thought that this TCM would solve my problem and I find I have the same issue with this TCM as well, it does not work at all.
So, I had Mike come back over with his car and we did the swap again and what do you know it works like it did before. We went for a longer drive and noted some issues, but these seem minor compared to the overall problem. The up-shift and down-shift points are off and the speedometer does not work. Other then that his TCM does electronically control my new trans.
I'm lost on this matter because Mike owns a 2009 G5 and my car is a 2006 LT Cobalt. My new trans from SMG did come out of a cobalt but at this point I don't know what model year it came from. The transmission will work with my new TCM, but it's purely in a mechanical aspect as there is no electronic control.
