stg 3 clutch no pedel pressure at all
Old Jun 24, 2009 | 11:38 AM
ssyeller's Avatar
Possible problems per dealer fluid is full
Master cylinder went bad
slave cylinder went bad
clutch itself has a problem
Any ideas.
Old Jun 24, 2009 | 06:57 PM
dvscobaltSS's Avatar
i would think the clutch was not bled correctly
Old Jun 24, 2009 | 07:26 PM
ssyeller's Avatar
Clutch has been in use for 1 year and 30,000miles
I don't think it is a bleed problem. Done at a dealer after hours.
Old Jun 25, 2009 | 06:18 PM
Smarty Art's Avatar
So it happened all of a sudden or over a period of time. Is there and DOT fluid leaking? Was there any work done to the car recently?
Old Jun 25, 2009 | 06:48 PM
ssyeller's Avatar
No work for 1 yr. No leak we can see
Talking to repair guy at the dealer. Most likely clip on the clutch rod came off since it was so sudden. Or clutch master cylinder went bad. Slave third choice.
Clutch master cylinder is a dealer item out of Reno.
Slave is available localy.
Point of interest clutch master cylinder is the same for 2.0 2.2 and 2.4 which does not show up on the cross reference books.
We are going to fix one way or the other tomorrow will advise what we found.
Old Jun 25, 2009 | 11:27 PM
Yeah I am betting its the master cyl. I just bought on this week because I am having issues with my clutch...did the dealer say how much they were going to charge to install it?
Old Jun 25, 2009 | 11:33 PM
ssyeller's Avatar
Approx 150 dollars.
I am doing with the help of Hayes repair manual.
Old Jun 26, 2009 | 04:03 AM
Man I am still on the fence about doing it myself. I have tried to bleed that f'ing clutch myself and no dice and the stealership charged me 135 to just bleed the clutch lastime I worked on it so we will see
Old Jun 27, 2009 | 01:17 AM
ssyeller's Avatar
Replaced the clutch master cylinder good to go
Looks like the clutch blew out the clutch master cylinder.
took about 2 and half hours and bled the clutch with no power bleed in about 10min.
Going to put together an after market stand alone clutch master cylinder because I don't want to do this every year or 30,000 miles.
Old Jun 27, 2009 | 05:41 PM
No power bleed??
Old Jun 28, 2009 | 11:43 PM
ssyeller's Avatar
No power bleed
My son had me working the clutch and he was doing some jerry rig thing and got it done in about 10min. I have not idea what he was doing. It has been working fine. Took it to a cobalt cruise and gave it a real workout.
Old Jun 29, 2009 | 04:31 PM
Smarty Art's Avatar
I can't figure mine out to save my life. It's hard getting into gear for the first minute or so on start up. After that I can move in any gear easily and even into first gear on stops. Tried vacuum bleeding and that didn't do much. I know its Not my cables. I know GM screwed something up when I had warranty work done. Something is wrong with my clutch hydraulics.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
