Weird Knocking Need Help PLEASE :(
Old Dec 29, 2011 | 11:28 PM
Dirtdevil77571's Avatar
Angry Weird Knocking Need Help PLEASE :(
Ok im having a issue when im racing and im at about 6100 RPMS and I push the clutch in to shift to 2nd and dump the clutch and floor it I hear and feel a knock like I have a bad motor mount. When troubleshooting I did the following put it in 2nd gear and let off the gas and got back on it it kind of knocked and then I did it again only in first gear this time and it knocked louder like a THUMP so I know its not my Engine. Could it be a Motor Mount going out and if so how many are there on this car and which one could it be?? Can someone please help I need this fixed before I go to a stage 3. Thank you so much in advance everyone. Have a great NEW YEARS!!!
Old Dec 30, 2011 | 08:28 PM
bratboy90's Avatar
I believe we have 1 motor mount, its on top passenger side easily visible.
We have 2 Tranny mounts, being the motor and tranny are connected, they kinda work together.
These are under the car, look up rotated tranny mounts and you will easily see where they are if you look under your car once you know what they look like. Tranny is on driver side connected to motor.
I'm not sure this is your issue at all, but I would inspect them to make sure their not broken.
FYI our tranny mounts came as "going out" from the factory unless you have an LNF. Helps to let us know what your running with current mods and stuff.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
Sep 30, 2015 08:18 PM
OrngBalt
Sep 16, 2015 07:45 PM
twilson380
Sep 14, 2015 10:52 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
