What is this spacer for?
1 Attachment(s)
consider it like a gasket that you need for proper alignment
neccessary for the f35
I use duct tape to hold it in place lol
Originally Posted by jrsmith
(Post 7591964)
It's just a plate, it doesn't have shims on that plate. I think it's just so when you separate the engine from the trans it doesn't corrode together. Keeps the edges clean when reinstalling
being the starter is bolted to the block it has nothing to do with starter/flywheel alignment.
its a shim, only used with the f35 tranaxle (ss/sc and ss/tc) to put the transmission in the proper location. my guess is without it the input shaft would hit the crankshaft or more likely the slave cylinder would bottom out and possible preload the fingers on the pressure plate |
Originally Posted by Sharkey
(Post 7595018)
| All times are GMT -4. The time now is 11:23 AM. |
