Will a Cosmo Racing Cavalier short shifter fit (2.2 & 2.4)?
#101
http://www.cosmoracing.com/productin...d=276&pid=1663
that's not set up with reverse lockout... the balt version is though.. even for the 2.2... if they're the same it's 60 after the shift knob... however thehy're on ebay for like 40 bux at times
#102
Original Hayden Fanatic
that is basically the same shifter i got..but i only paid $25, the "reverse lockout consists of a bracket that can be unscrewed... but i like the purple coller that is on my
#105
no but those come with detailed instructions so you don't have to look at TWM's hense why it's an easier solution no messing with the reverse lockout or worrying about directions
it's a little more expensive... but some people might want to opt for it if it's easier in the end ya know?
#107
yep, i got it, yeah i cut the base, yep i got the purple collar. i originally ziptied the boot to the top, but decided i liked the purple. Here is a larger version of the avatar:
#111
That was my thought, but SSBOOST did it without cutting. You must have missed his post.
Boost, Did you use your new boot? Pic?
#112
Got a pic, didnt use new boot yet. I broke the thing that the boot is stapled to so I got to get a new one of those and ill trim the JDM boot and staple it to that. I DID NOT DO ANY CUTTING TO FIT THE SHORT SHIFTER. And yes it came with the purple RLO but I just took it off. Shorter throw, looks sleek and love the knob, here ya go.
#113
I went for it, ordered the cheap shifter, hopefully I get more than I paid for. My car doesn't like to shift into 1st or reverse probably atleast once a day, I have to be a little agressive to get it in. I might have to look into that before installing the shifter or I'll have to put the stock one back in before taking the car to the dealership.
#115
if your talking about takes out the reverse lockout, i didnt even do that, it holds up the shift boot nicely
#117
No modifying, correct. I also have the same problem a couple times a day with it not going into 1st or reverse. What I do to make it work is shift into 3rd (always works) and then go to 1st or reverse, works everytime.
#118
#124
Is the spring that came with the package suppose to go under the shift knob to put pressure on the RLO, used in the assembly, or only needed for the Cavalier? Does it work better to leave the RLO on to hold the boot or remove it? Thanks.
