2.2 sc numbers too low?
by the looks of things my numbers are a bit lower than everybody elses. what could be hurting my numbers?
MODS: m62 w/3.0 pulley zzp 3in intake badmab header zzp 2.5in downpipe gmpp touring exhaust zzp s3 heat exchanger 60# injectors trifecta tune and i have an auto tranny. think its just a conservative tune? http://i1219.photobucket.com/albums/...12133826-1.jpg |
Shitty tune. A HP tune would get you going a lot better. Even with trifecta though you should be at least 220. MP81 was 220 before an exhaust even.
tune? lol Im about to add a zzp dp when they actually ship it out to me -_- but I hope my numbers arent that low :/
Maybe cause cause your auto? I've heard autos dyno lower than manual but not sure if it's true
would your dp have any effect? on zzps site it says 2.5s are mainly for na and 3 going to 2.5 are great for sc but I dont really know if it has much effect on the overall performance
(Post 6502937)
I run a 2.5" downpipe on my car, and it is the optimal size for my setup (275whp on pump gas, 285whp on race gas). ZZP, has that disclaimer so N/A 2.2L & 2.4L guys don't go install a 3" downpipe on their cars. Auto will have a little lower power to the wheels than a manual. OP, I don't think your numbers are bad at all. Don't get caught up on dyno numbers. You can go to a different dyno, and end up with totally different results. |
bika barely broke 300whp on this dyno
(Post 6502994)
No.
(Post 6504178)
soo does this mean I ordered the wrong downpipe for my setup then?
(Post 6502994)
No.
I run a 2.5" downpipe on my car, and it is the optimal size for my setup (275whp on pump gas, 285whp on race gas). ZZP, has that disclaimer so N/A 2.2L & 2.4L guys don't go install a 3" downpipe on their cars. Auto will have a little lower power to the wheels than a manual. OP, I don't think your numbers are bad at all. Don't get caught up on dyno numbers. You can go to a different dyno, and end up with totally different results. You can try to go with the 3 inch DP, but you shouuld be fine with the 2.5, so stop stressing the DP... If you are trifecta tuned, have you sent vince any data logs? |
Originally Posted by Vander Nars
(Post 6504236)
Naw either size will work, zzp did put that the 3in is intended fot the sc, and me and staged have disargeed about this before but we both can agree that either size works. So if u went woth the 3 u are golden juat dont go 3" catback unless u go turbo.
but that disclaimer is still not clear to everyone. The 3" is mentioned to be intended for blown cars, because a 3" downpipe on a N/A car is not neccessary. That's what that disclaimer is for. It's not telling you if you are supercharged you should by the 3" downpipe. It's letting N/A guys know they should buy the 2.5" downpipe. but yes, both downpipes will work fine for blown cars. |
(Post 6502994)
No.
Thats almost same numbers to another 2.2 thats SCed with almost identical mods with HP tune.
don't worry about numbers don't mean anything go run it and see the real results
