Cobalt SS/TC ZFR FBO
Is it commanding somewhere around .91 - .93ish lambda up top like that or is the ecm going into open loop on you for one reason or another? I know the tail pipe sniffers tend to register a couple tenths leaner (afr) as compared to a pillar mounted wideband which is reading much further up in the stream, but even at that, it's still looking a little lean for my liking. Not bad numbers regardless.
That sniffer must be all sorts of off then. I've seen them as far as a few tenths afr off, but .5 - .6 lean is pretty extreme. Might as well not even graph afr at that point then. lol
I sure hope they don't trust in those readings all too much when tuning on that dyno. lol
When I did my TVS dyno it was a little lean compared to what I usually run it at, went from 11.6 quickly to 11.8 and then 12.1 up top, and on the sniffer it showed up mid 12's up to 13.0 up top. My car also blew the sniffer out of the exhaust a little, so that may have had something to do with it lol
jcalvin1126
09-11-2015 10:24 AM
