Dynoed 10/8/10: Fueling myths or fact?
Did three runs for each AFR test. Here are one of three from each afr category.
Blueline: 12.0 afr 24* max
Green line: 11.0 to 12.0 afr 24* max
Red line: 14.7 to 12.0 afr 24* max
4th gear, 75* air temps, 29% humidity, 100* iat1 & 122-126* iat2
And just for comparison; here's a local stock LNF dynoing 3rd gear vs my 247whp line.
2.7 m62
ported s/c and lower manifold
3" zzp intake
7gph 50/50 mix
jbp header
2.5" catless
2.5" spintech custom catback
dual pass, 4 gallon flow thru
Hptuned
YouTube - 1st run
my friend asks me for my thoughts on my massive 247whp!!! he also likes to ramble lol
http://www.youtube.com/watch?v=aiNep...e=mfu_in_order
2.7 m62
3" zzp intake
7gph 50/50 mix
jbp header
2.5" catless
Hptuned
YouTube - 1st run
now i'm a huge noob to tuning and afr's (still learning before i get tuned) but wouldn't the sloping of the afr's be good for fuel economy as well if the owner desired to save that somewhat?
Hahaha well I know that, but a sloping afr would go across all trim cells starting at 17 which should be idle and eventually getting to wot with the commanded afr. if I'm wrong please correct me, I'm just trying to figure out which way to go with my tune once I get my cmp sensor and phase silonoid (sp) replaced next week
Your losing me... :/
If your tuning yourself... this is all you need to do... get a good base file for a foundation to start on.
MAF tune it to 0-1% error
pick a desired AFR for your application.
Work the living **** out of your timing table (hand smooth, hand smooth, hand smooth, hand smooth)
ya if we were in person i could better explain what i'm asking. and ya i won't be doing the tuning myself right off the bat but will be later on down the road
