This Ford Guy has much respect for 2.4 Ecotec Motor.
I have no idea what the limits are of this Engine stock. Before you go bashing me telling me this is a ticking time bomb you will not get an argument out of me. I simply did what the customer asked for and knows that **** happens when you push the envelope of horsepower. After running a number of 12.60's passes at 108 mph the customer wanted more. Car had been running the same 12 psi making 275 whp on pump gas. We were limited to around 13-14 degrees of timing for the car would not make any more power with more timing. It was then I suggested we switch to E85. We were then able to run as much as 22 degrees of timing without knock. Owner of the car is looking to switch to 80 lb injectors and up the boost to 16 psi and see if we can break the 400 whp mark.
I am not here to advertise the business. Just wanted to share the results with you and get some feedback from those who are familar with this engine. If I need to delete the dyno information in the graph I will so the thread does not get deleted and/or I get banned.
While this is not my cup of tea I can see why the 2.4 Ecotec motor is loved by the GM FWD community. This is one bad ass little engine. Here is a run down of the car.
Thanks!
100% Stock 2.4 Ecotec Engine
ZZP Turbo Kit - 2 1/2 exhaust with resonator and magnaflow muffler.
Fully Built Tranny - 3000 RPM stall converter
Air to Water Intercooler
255 lph Fuel Pump - Aeromotive Regulator - 60 lb injectors
Mix in some E85 and tuning and you get this....
14 PSI running out of injector Tires spinning on drums causing the dip in horsepower at the begining of the run.
12 PSI
Time for 80lb injectors and more boost. 400 whp out of a stock 2.4 here we come.
.JPG)
Thanks!
12 PSI
is that a 5 spd or an auto? because 275 on 12 psi is rather low
however the 360 417 numbers.. DAYUM
and thanks for reminding me i'm gonna need new injectors when i put my new turbo on lol
This was an auto with a 3000 rpm stall converter. TCC was left unlocked for I was afraid the lock up solenoid would not hold. All pulls were made in 3rd gear. I am sure the numbers would be much higher with a manual transmission car.
Like I said in the original post the car would not make any more power with more then 14 degrees of timing on pump gas. The knock sensors would start to tickle a degree at 15 degrees.
As you can see a 1 psi gain gives it 20 whp on E85
Don't nit pick his results. Those are great numbers for that stock engine. ZZP advertises 356whp with that same kit.
Have we had a stock LE5 pushed to failure with a good tune? Most of the failures I have seen have been with questionable tunes and questionable setups.
. At the same time I am going through the learning curve. Hopefully may 3800 and LSJ knowledge will come in handy with the 2.4 Ecotec.
Nice job on the Saturn. We did 356 on 110 octane at 15-16psi, so these numbers are pretty good.
We don't advertise the kit to make anything close to that on 93 octane. It is good for 280-290 on stock valvesprings and 300-310 with upgraded valvesprings. We pushed it a lot harder on 110 octane.
This Saturn does have upgraded srpings.
I took another look at the graph before I left the dyno for a break. Decided to check the numbers using Standard, SAE, and Uncorrected.
360.6 WHP 417.2 WTQ - SAE
373.2 WHP 424.3 WTQ - STD
359.2 WHP 414.9 WTQ - Uncorrected
Regardless of the type of dyno used or the correction factor this car is making some power.
This makes me wish my car wasnt an 08
Good numbers!
Ive thought about going with a variation of the zzp stage 1 kit more than a few times. (air/air and meth instead of the liquid intercooler etc etc etc)
But being an 08 I might as well have a spare 2.4 on standby
Good numbers!
What is the downside to the 08 cars?
06-07 Had Forged Rods, 08 doesnt.
this makes me wanna build my 2.4. but with 132K miles, ill start another motor on the side for when this one goes. im sure one with a good bottom end from an 06-07 all refreshed will hold up fine!
Its good that he was able to make kind of power with less boost.
Once again elecblue06 we were limited to 14 degrees of timing. When trying to go to 15 degrees of timing we started to see knock. So we left the timing at 14 degrees and he was able to race his car with a number of passes without blowing up his car. Obviously the car like E85 for we were able to pick timing to 22 degrees and gain 50 whp with the same boost.
So to say "oh **** lol" I am not sure what you are getting at. For all we know we had shitty gas or maybe it was because we were making pull after pull with a warm engine and warm IAT's.
If Matt from ZZP comes in and pokes fun at the results on pump gas then I might want to be concerned and diag the problem. However Matt said the results were good for E85 and that was the purpose of the post. If it was your car that made the 275 whp on 10 psi I would say post up a graph. However it is not your car and you do not have a dyno sheet so that is not an option.
I will be posting more results once the customers switches to the bigger injectors and we add 2 more PSI of boost.
