New Official Dyno Thread (2012)
#226
Come on down, I bet you'll be heartbroken as its the dyno around here people don't dyno much(and shop is criticized) because people are disappointed with their results(they barely use it. I actually went there because I wanted to know what numbers I would put down, thinking high 200's in HP mid 300's in torque. I dyno'd 357whp 410trq without cams, with cams I got 368whp 446wtrq so there was a gain for sure with the revisions I was getting from Term2. You are the first person to ever say Dyno Dynamics suck. With that last dyno the tune I was able to pull a 4.2 60-100 stock turbo.
#231
Can u put me on the tc list not stock turbo...zzp s256et catted downpipe external wastegate zzp charge pipes zzp intercooler zzp 3 inch catback no resonator. pump gas. i dont have a pic of the graph i just have a vid. 449whp 360wtq
#233
Went to LS Fest in bowling green today... talked the dyno operator into letting me make a pull (even though it was only supposed to be for LS vehicles). This is the tune my car drives every day.
Mods:
50/50 E85
79lb Lucas Injectors
RAW CAI
BRK7E's
Ingall's Torque Damper
GMPP Trans Mounts
Hurst Short-Throw-Shifter
3" Downpipe w/ Magnaflow High Flow Cat
3" Mandrell Bent Exhaust w/ a Dynomax Super Turbo Muffler
Do-it-Yourself Dual Pass
Al Neal Inductions Ported Head
ZZP 78# Springs
Pacesetter Mid-Length Header
Harrop TVS Supercharger w/ 75mm Pulley
OTTP Stg 1 Axles
GMPP Clutch
CX Heat Exchanger
HPTuned
Looks like it had some spark blowout on top. but I'll take it for an impromptu run.
Mods:
50/50 E85
RAW CAI
BRK7E's
GMPP Trans Mounts
ZZP 78# Springs
OTTP Stg 1 Axles
GMPP Clutch
CX Heat Exchanger
HPTuned
#234
Mods:
50/50 E85
RAW CAI
BRK7E's
GMPP Trans Mounts
ZZP 78# Springs
OTTP Stg 1 Axles
GMPP Clutch
CX Heat Exchanger
HPTuned
Mods:
50/50 E85
RAW CAI
BRK7E's
GMPP Trans Mounts
ZZP 78# Springs
OTTP Stg 1 Axles
GMPP Clutch
CX Heat Exchanger
HPTuned
#235
Mods:
50/50 E85
RAW CAI
BRK7E's
GMPP Trans Mounts
ZZP 78# Springs
OTTP Stg 1 Axles
GMPP Clutch
CX Heat Exchanger
HPTuned
Mods:
50/50 E85
RAW CAI
BRK7E's
GMPP Trans Mounts
ZZP 78# Springs
OTTP Stg 1 Axles
GMPP Clutch
CX Heat Exchanger
HPTuned
#239
yea i think i saw your car there 383 stroker ( hard to miss when it was the only cobalt ss there lol) you got a clean car and it sounded good. i was back there helping that drift crew pull the motor and put it back in before comp.
#240
Yeah, i saw one of the 240s looking like it was mid motor-swap on Saturday morning but i didn't know what had happened to it.
#241
yea he didnt have any oil pressure pulling off the trailor on friday and we just happened to walk by as they were trying to figure it out and we just had an oil pressure problem in my buddies ls1 swap so we threw out a few ideas and before we knew it we were pullin the motor out with him lol. got the motor and trans out, took the trans off the block and all back together and back in the car all on friday...... then saturday he was still having problems, it was better but not 100% but we finally got it figured out about 15- minutes before there competition started. and that was his first v8 drift car with absolutely no practice goin into it and still pulled off like 5th or 6th i think, it was crazy.
#244
My Dyno results
Need to fix those plugs and regap to .028
Running Trifecta Tune, 60LB Injectors, 2.8 Pulley, Badmab Header, ZZP Catted downpipe, ZZP resonator, Dynomax muffler, Option B, Mercedes AMG secondary H/E, Ingen CAI. NGK BKR7E's
#246
TTR Powered
Dyno Jet: Track Masters Inc Huntsville AL.
Turbo Tech Racing LNF Manifold.
Revised BNR 2871 Turbo.
K&N Short Ram Intake.
Injen Charge Piping.
TR12 Intercooler.
MAF Relocation Pipe
GMS1 Sensors
Comp Cams Stg 1 W/LFPL
#82 Springs W/ Retainers
Neutral Balance Shafts
Wiseco 86mm Pistons
4340 Connecting Rods
Tial Q 50mm Bov
Full 3" Exhaust With 3" Hahn Muffler (No Cats)
4.05 Transmission W/O LSD
Hptuned by CCSS3
93 Octane Pump Gas Only. (No Meth, No E85, No Race Fuel)
415Whp / 381Wtrq
TR12 Intercooler.
MAF Relocation Pipe
GMS1 Sensors
Wiseco 86mm Pistons
Tial Q 50mm Bov
Hptuned by CCSS3
415Whp / 381Wtrq
#248
Thoughts?
#249
TR12 Intercooler.
MAF Relocation Pipe
GMS1 Sensors
Wiseco 86mm Pistons
Tial Q 50mm Bov
Hptuned by CCSS3
415Whp / 381Wtrq
TR12 Intercooler.
MAF Relocation Pipe
GMS1 Sensors
Wiseco 86mm Pistons
Tial Q 50mm Bov
Hptuned by CCSS3
415Whp / 381Wtrq
I added u to the list, but please put your mods into the format found under the legend on pg. 1 (post# 1) of this thread.
Once you do that, I will add your mods. Thanks.
#250
Update: 11/6/12
- Cobalt Daddy
- Jared B
- jvirginillo
- m33pm33p
- Team SS
Added!!
It could be a bad coil, but some LSJ's don't like copper plugs....
My car hated the ones you are running (even though "most" sware by them).
Inspect your coil packs, make sure the plugs are torqued to spec, and go from there.
- Cobalt Daddy
- Jared B
- jvirginillo
- m33pm33p
- Team SS
Added!!
