The Official Dyno Thread 2015
#501
I did not forget you. Also, you need to list your mods as per the legends on the first page.
I'm not doing that part.
If I didn't get to you, I just ran out of time.
CobaltSS.net is not my main priority in life.
I say this all the time... if you added a graph and your mod list (correctly) to this thread you will be eventually added.
Tdubbs (12-16-2016)
#505
you cry
#509
I use the stock exhaust manifold so mine should be in the K04 group too it's also a borg warner which is stock
#513
Saw this and realized some of ours weren't up here!
So, here is Turbo_Tim's M62 Powere Ion
<a data-flickr-embed="true" href="https://www.flickr.com/photos/137402216@N06/31754305066/in/dateposted-public/" title="20161221_164817"><img src="https://c3.staticflickr.com/1/432/31754305066_2f26cb0b20_k.jpg" width="1152" height="2048" alt="20161221_164817"></a>
401 whp
330 wtq
Mustang dyno
3.5" Intake
Header
Downpipe
Exhaust
ZZP Tune
80# Injectors
2.7 Pulley
Heat Exchanger
Single Pass
LS4 Throttle Body
Ported Head
LSJ Stage 3 SC Cams
M62
E98
2.4 Motor
Valve Springs
11.1 Compression
Neutral Balance Shafts
401 whp
330 wtq
Mustang dyno
3.5" Intake
Header
Downpipe
Exhaust
ZZP Tune
80# Injectors
2.7 Pulley
Heat Exchanger
Single Pass
LS4 Throttle Body
Ported Head
LSJ Stage 3 SC Cams
M62
E98
2.4 Motor
Valve Springs
11.1 Compression
#521
#525
