door speakers with stock pioneer system????
I have an 09 ss with the factory pioneer system. What speakers can i use to replace the door speakers? I don't want to bypass the factory amp.
6.5" round speakers will work
From what im reading the factory system is 2ohm, most speakers im finding are 4ohm. If i use a 4ohm i will be loosing quite a bit of volume. Is there a 2ohm speaker out there that will work with the stock amps, increase sound quality and not loose power?
JBL/Infinity
does the factory amp have enough power to push those? Something like these seem to be for a larger amp...or maybe im wrong..http://www.ebay.com/itm/6030CS-INFIN...item1c1d0aeb08
Are you raising volume to max level in your car? If not, then your stock amp will be fine with 4 ohms speakers! Just raise the volume and you'll be fine, no?
^no... sleepy i would look into co-ax speakers not components. but if you wanted yes you could install those. the stock amp isnt going to give those or any other speakers the full power they can handle but it doesnt matter because u dont really need it to.
ok, issue im having is finding 2ohm anything.
onlinecarstereo.com maybe?
from what I see they have 49 different 2 ohm options
CDT has some convertible 2ohm coax 6.5's. Then if you wanted to change to a component setup you just have to pop off the tweeter.
do yo know if they still offer them?
Originally Posted by Olivier12444
(Post 6159133)
(Post 6174411)
nooope. u lose like all ur bass. did it in my old car, got 4 ohm speakers.. had no sound really, stock was better
free bump
(Post 6174370)
Yup.. Something like these: CL 6EX.2 6.5" coaxial 2-way speaker system 1 pr CL-6EX 6.5" woofer w/ ¾" silk dome tweeter Built-in 6dB crossover Built-in tweeter protection Butyl cone surrounds Carbon-reinforced cones http://www.cdtaudio.com/images/coaxials/cl-6ex_lrg.gif CL 6EX.2 installer friendly 2-way coaxial speaker system Technical specs and contents: 1 pr CL-6EX 6.5" mid woofer Coaxial mount ¾" silk dome tweeter 6db built-in crossover Built-in Poly switch tweeter protection Butyl cone surrounds Carbon-reinforced cones Power handling: 110 watt RMS @ HPF 120Hz. Frequency response: 65Hz-20.000Hz. Impedance: 2 Ohm Sensitivity:91.3dB Mounting depth 2.5" |
(Post 6174423)
would these work? seem pretty snazzy to me...
PAIR JBL P662 150W RMS 2-WAY POWER SERIES 6.5" VEHICLE STEREO COAXIAL SPEAKER | eBay Infinity Kappa 62.9I (KAPPA 629I) 6-1/2" 2-way Kappa Car Speakers (050667110031) | eBay |
Originally Posted by -TurboSS-
(Post 6174513)
CL 6EX.2 6.5" coaxial 2-way speaker system 1 pr CL-6EX 6.5" woofer w/ ¾" silk dome tweeter Built-in 6dB crossover Built-in tweeter protection Butyl cone surrounds Carbon-reinforced cones CL 6EX.2 installer friendly 2-way coaxial speaker system Technical specs and contents: 1 pr CL-6EX 6.5" mid woofer Coaxial mount ¾" silk dome tweeter 6db built-in crossover Built-in Poly switch tweeter protection Butyl cone surrounds Carbon-reinforced cones Power handling: 110 watt RMS @ HPF 120Hz. Frequency response: 65Hz-20.000Hz. Impedance: 2 Ohm Sensitivity:91.3dB Mounting depth 2.5" |
Looking at these 2ohm options it seems they require more power than the factory amp can put out, which make me wonder if just replacing them with the stcok amp will improve the sound quality at all??
dont be fooled as far as speaker speakers go not a single one "requires" an amount of power. they just have the ability to "handle" a certain amount if that makes any sense. just like your cobalt can drive 140 mph doesnt mean you have to drive that or not at all.
or a better reference would be tires. if your tires are rated at 140mph u can use them at that speed for an extended amount of time and generally would be ok. you could also excede that by a bit and again be ok BUT for a very very short period. and driving at 35mph or whatever will last for the life of the tire as long as they are roatated balanced ect. power lets you get louder and often will get the speaker to play cleaner but the cleaner part is sorta complex. all the speakers mentioned thou will improve the sound quality. no doubt in my mind. there's only a very few that wouldn't and your wont really find them in 2 ohm. |
