Headlight help
My HID driver side went out. I keep blowing my low beam driver side fuse. I checked the bulb and ballast by swapping everything around, no go still don't work. Everything else on the headlight works fine. I have no idea what else to do. I read something about swapping the left and right relays to see if it's the relay that's bad but I have no idea which ones are the right relays also if anyone has any other ideas what it could be. I am mildly knowledgable about electrical stuff but I take direction very well. 😁. Any help would be appreciated.
If you keep blowing fuses then your shorting out somewhere. Run through your harness and make sure all your wires are connections are good.
Originally Posted by double clutch
(Post 7588860)
anything could cause a short. If you unplug the wires altogether see if it still blows fuses or not
Originally Posted by Dre Day
(Post 7588873)
I didn't see anything obvious when I was working on it last night. Everything seemed to be in good order. The only thing I could think of is I guess the previous owner had halo headlights because I see little red what I think are quick connects right at the base of the harness? Could that cause the short even though there's nothing attached to it.?
(Post 7589289)
try plugging in just the harness not connected to anything and see what happens.
