HELP! Blinker doesn't snap back to neutral
I have an 07 Cobalt LS, and after a lot of quick successive turning, my blinker stopped switching back into the neutral position. It doesnt click back after i signal a left or a right turn. Does anyone know how to fix this? if so is it an easy fix and how much would it cost me?
Originally Posted by Amoney
(Post 7187412)
Just had to have the turn signal switch replaced under warranty on my Dad's 2007 Malibu. Had problems with the turn signal switch on my brother's 2007 Pontiac G6 he had too.
Crate engine depot sells them and after you take off the bezel surrounding the steering column it's a wire you disconnect and a latch you push on.
(Post 7187426)
(Post 7187744)
what tools would i need to do that, im not trying to mess around with the air bag. |
Yep it's either 7 10 or 8 mm and both of your hands.
:lol:
Originally Posted by Sox-Fan
(Post 7188045)
So the switch and latches that make it snap back are all one unit? There has to be some part on the steering wheel that hits a latch on the blinker to make it snap back.
Any idea of the cost? |
You need a complete new blinker lever it broke internally, I went thru 2 of those in my Base model
252032778382 that's the item number for what you would need on ebay
all you need is a mid-deep 7mm socket and either a pick or small flat heat screw driver. super easy to do and terribly common. Gm released updated parts to increase reliability but haven't had anyone buy the parts yet bc you have to change a lot. I have a couple old style multifunction switches in my box right now at work I rebuilt actually.
I have yet to see one that has broken the part on the column than resets the switch, and I've probably changed 30-40 of them. the design columns we have were put in everything lol |
What is it like 3 or 4 bolts pop that cover off around the steering wheel. Push the clips one on top the other on the bottom side, pull the lever and disconnect. Pretty simple
Yep, ill get some pics. takes me like 5 min to change one out lol
Lol I changed that with no how to the first time so it's simple for sure
pretty cut and dry.
remove, install. done. |
