How to power a 3500 watt system
Good power wires, and good grounds. Might be a good idea to run a dedicated 0 gauge run from the alternator to the battery, and also ground your block to the chassis.
If voltage keeps dropping you'll need a high output alternator.
A single good deep cycle battery should power 3500 watts no problem. Look into a odyssey 2150 or similar sized battery.
