What could be the problem?
Old Nov 6, 2016 | 01:25 PM
Ls5speed's Avatar
Hi, I recently bought a 2006 cobalt ls, and I LOVE IT! I recently had the clutch replaced and now I have another problem. This only happens once in a while... maybe once/twice a week but is becoming more often... sometimes when I turn the key, all of the electronics come on... dash lights, radio, cigarette lighters, etc... but it doesn't turn over. As a matter of fact, it doesn't make any noise. I can hear the fuel pump but that's it. No clicking ticking or anything. It's not the starter because it starts 70% of the time. I'm getting frustrated bc I can't count on my car to start half the time. What could be the problem??
Old Nov 7, 2016 | 07:07 PM
tomj77's Avatar
Well what do u have to do to get it started after it does that
Old Nov 8, 2016 | 10:17 AM
I'm going to assume they roll start it.
It could be a number of things, start with getting the battery and alternator tested. If those check out good, then check the bolts in the fuse box and make sure they're tight (30-40ft/lbs). After that it's grounds and starter.
Old Nov 8, 2016 | 01:48 PM
Ls5speed's Avatar
Ok thanks... I'm not a HUGE car guru, so where would the bolts in the fuse box? Thanks again for the help.
Old Nov 8, 2016 | 01:50 PM
Ls5speed's Avatar
Well that's what's weird... if I just wait it'll usually start... sometimes I have to just jam the key in and out and other times it'll start right up after 2-20 mins... it's really weird. I bought it might be a clutch position sensor so I'm going to try and pick one of those up.
Old Nov 8, 2016 | 01:56 PM
Pop the cover off the underhood fuses, you'll see the bolt heads I'm talking about. I forget how many there are.
Old Nov 8, 2016 | 06:17 PM
Ls5speed's Avatar
Ok thanks a ton for the help!
