Your recommendation
I need to replace my fuse box (i have that covered) and one set (passenger) of wires from fuse box to the headlight. Might as well replace them both. Have it prepped and want to upgrade to good enough wires to handle projector HIDs and fogs. Recommend me a set?
Upgrading wiring to somthing larger is fine. But you'll need to solder it of course. now if its a.volt referenced wire changing the thickness of the wires a no go...
Please don't make more than 1 thread on the same subject
James.. I guess I need to go on and do some research through an HID thread... My wiring for my high beam is shot for the passenger side. I want to hurry up and just replace it and use my OEM replacement headlight for now and run HID later. No clue how to go about doing that. And I got my iron ready to go ;)
TommyP... My bad. Just figured this might be a better area to post my question. |
