06cobalt racer January FCOTM thread
Location: Altus AFB, Ok Car Info: 2006 Cobalt SS/SC Stock Options: XM, G85 with recaros, Sunroof CURRENT MODS: Engine/Drivetrain Modifications: magnaflow 2.5" cat-back stock air box mod with AEM dryflow filter zzp shorty header Vibrant 3" DP w/ highflow cat 2.5" exit dual pass endplate OTTP stage 2 rotated mounts with solid bushings. zzp stage 3 and stock h/e custom flow-thru supercharger coolant tank ottp stage 1 kit* *60lb Flowmatched Injectors *2.8" Smoothflow MPS pulley system *Injector Harness *Larger Idler Pulley *NGK 1 Step Colder Copper Plugs upgraded shifter linkage bracket zzp phenolic spacer adjustable belt tensioner meth injection with 8 GPH nozzle and LED activation light 2.5 gallon tank throttle body spacer tapped for meth injection WOT box with launch control and 2-step Trifecta custom tune with adjustable rev limiter Suspension Modifications: ark dt-p coilovers ottp hardcore bar ottp delrin leading control arm bushings ottp spherical trailing control arm bushings zzp stainless steel brake lines with DOT type 4 fluid Wheels/Tires Modifications: 225/40/18 hankook ventus evo v12 tires Enkei EKM3's 18x8 Interior/Exterior Modifications: AEM uego gauge aeroforce interceptor gauge dual steering column bezel gauge pod ottp shifter bushings TC upper grille TC lower grille custom retro headlights with 6K HID's, red halo's and audi style led's (recently removed to fix them) 6K HID fog lights with red halo's carbon fiber front and rear bowtie ARK shorty antenna red powdercoated valve cover "supercharged" brushed aluminium door sill plates FUTURE MODS Install my TVS in the winter!! install OTTP STS the first day i brought her home! https://www.cobaltss.net/gallery/fil...4/9/163714.jpg http://www.flickr.com/photos/jonnyc127/10075356974/, on Flickr http://www.flickr.com/photos/78379868@N05/10381044053/, on Flickr https://www.cobaltss.net/gallery/fil...4/9/032__2.jpg https://www.cobaltss.net/gallery/fil...4/9/014__5.jpg https://www.cobaltss.net/gallery/fil...006_210762.jpg https://www.cobaltss.net/gallery/fil.../1/4/9/001.jpg And finally me on the Nurburgring GP track |
those new pics are sweet!
(Post 7227916)
im jealous that you got to run on the nur-however the hell its spelled-gring. great looking car
Originally Posted by southal cobalt
(Post 7231685)
Nice car. |
(Post 7231685)
Thanks though, that place is amazing!! Both the GO track and the North loop. |
