November 2010 FCOTM Winner - Blur.fx
Pave It All...
Eric
Iowa City, Iowa
2007 Cobalt SS/SC
Stock Options
Iowa City, Iowa
2007 Cobalt SS/SC
Stock Options
- Victory Red
- Limited Slip Differential
- Ebony Seat Inserts
- Standard Spoiler
- Power Sunroof
- Over The Top Performance Polished 3" Intake
- AEM Dryflow Filter
- SMS Big Bore Throttle Body Ported & Polished by Stiegemeier
- Polished Harrop HTV1320-LSJ Supercharger
o Nate's 2.70" & 2.90" Pulleys - Over The Top Performance Ported & Polished Lower Intake Manifold
- GMPP Dual Pass Endplate - Option B
- M2 Race Systems CNC Ported Head
o Supertech 78lb valve Springs
o Supertech Stainless .5mm Oversize Intake Valves
o Supertech Inconel .5mm Oversize Exhaust Valves
o ARP Head Studs - Cobra Heat Exchanger
- -10 AN PCV Breather Line
- Snow Performance Meth Injection Kit
- 80 lb Injectors
- NGK BKRE7 Spark Plugs
- ZZP Ceramic Coated Mid Length Header
- 3" Downpipe with High Flow Cat
- GMPP Performance Sport Cat Back
- Tuned by Area47
- Flat Red Powdercoated Valve Cover
- Polished Coil Pack Cover
- Polished MRZ Performance Fuel Rail Cover
- Polished Modern Performance Oil Fill Cap
- Polished J-Body Performance Heat Shield
- SS/TC Upper Grille
- SS/TC Lower Grille
- Painted Bowtie
- Shortened Antenna
- 35% Window Tint
- Luminics Ultra White Headlamps
- Luminics Ultra White Foglights
- Chrome Turn Signal Bulbs
- ! Daytime Running Lamps
- ! Trunk Emblems
- ProParts A-Pillar Triple Gauge Pod with Defi White Racer Gauges
o Boost
o Oil Temperature
o Exhaust Gas Temperature - Dual Gauge Pod Bezel
- Dual Aeroforce Interceptor Scan Gauges
- AEM UEGO Wideband Air/Fuel Gauge
- Hurst Short Throw Shifter
- GM Accessories Armrest
- 18"x8" Gunmetal ALT Sektors
- 235/40/18 Dunlop Direzza Sport Z1 Star Specs
- Wilwood/TCE Performance 13" Front Brake Kit
Two Piece Cross Drilled & Slotted Rotors
Red DynaPro 6 Calipers - Wilwood/TCE Performance 11.75" Rear Brake Kit
Red Parking Brake Calipers - Megan Racing Street Series Coilovers
- Polished J-Body Performance Strut Tower Brace
- Polished Turbo Tech Racing Upper Engine Mount
- Over The Top Performance Stage 2 Billet Rotated Transmission Mounts
- Over The Top Performance Steering Rack Spacers
- DriveShaft Shop Level 2 Axles
- BWoody Sway Bar Links
Pave It All...
Procrastination is one of my best skills.
Not exactly... Euthanasia stripped the powdercoat off of this one and polished it.
Thanks for the compliments guys!
