Japeatr's October FCOTM
10 Attachment(s)
Attachment 11292
Name: Vaughn Watson Location: Frisco, Texas :usa: Car Info: 2005 Cobalt SS/SC, Original owner! 66,230 miles Stock Options: XM Modifications: Engine LSJ - Girdled Gen 1 block with Custom spun ductile moly sleeves Recoated Diamond 9.5:1 pistons Pauter Rods Oversized Titan wrist pins Total Seal AP Stainless Rings with Napier cut second Drilled oil passages for mains Clevite H Rod bearings GM Main Bearings GM Main studs - All new Lightened crank (1.2lbs) Balanced rotating assembly ARP Head studs Deleted Balance shafts – Level Zero Motorsports Balance Delete Bushings/Cut stock shafts Timing Bolts enlarged to M8 with ARP bolts Block bed plate tapped for 1/2"NPT and -10 oil return GMPP Adjustable cam gears Bates solid lifters ground for proper lash ARP Cam Cap Studs Custom ground camshafts for solid lifter slow down ramp Modified Thermostat housing for Electric Water Pump Modified Water pump housing for Electric Water Pump Custom auxiliary oil cooler PRP Electric Water Pump Powell Race Shop Air/Oil Separator Valvecover custom powder coated Harrop Grey tapped for 6AN for PCV Turbo Tech Racing Upper Engine Mount Turbo Setup S256 with Stainless .70 AR housing and ARM Performance ported compressor housing Tial MVS wastegate with ZZP dump tube Tial BOV ZZP cast turbo manifold Over The Top Performance intake manifold custom powder coated Harrop Grey, TB Spacer w/ 1/8”NPT port Over The Top Performance charge pipes custom powder coated Harrop Grey ZZP LNF Intercooler OTTP Alternator Pulley Ported LSJ throttle body TurboXS GT Catback Fuel System Powell Race Shop Custom surge tank and Bosch 044 inline pump Deatcherks D300 in-tank pump Bosch 160# Injectors OTTP RSFS with Fuellab regulator Nitrous Setup NX Nitrous Express Proton Plus Series Nitrous System NX Nitrous Express Single Shark nozzle NX Nitrous Express Nozzle adapter NX Nitrous Express Stainless braided nozzle lines NX Nitrous Express Extra-long braided stainless feed line NX Nitrous Express Stainless fuel line NX Nitrous Express EFI Wide-open throttle switch NX Nitrous Express 40 amp relay Custom Relay harness NX Nitrous Express Fully automatic bottle heater NX Nitrous Express Pressure transducer NX Nitrous Express Liquid-filled N2O pressure gauge NX Nitrous Express NHRA-approved pressure release fitting NX Nitrous Express NHRA-approved blow-down tube NX Nitrous Express Remote Bottle Opener NX Nitrous Express Purge valve for Lightning series Custom timing retard harness Performance Electronics Innovate LC1 wideband wired to a relay for the AC pressure switch (Standard HPT) Innovate G3 Oil Pressure Gauge Innovate G3 Boost Gauge Innovate G3 Wideband Gauge Raptor Shift Light N2MB WOT BOX MSD 8244 Window Switch for Nitrous Transmission Southbend Stage 4+ Clutch Luk Flywheel ARP Flywheel Bolts 209-2801 ARP Pressure Plate Bolts 101-2201 Powell Race Shop Upgraded Roll Pins Over The Top Performance rotated transmission mounts with Powell Race Shop bushings Over The Top Performance upper transmission mount Suspension/Wheels TSW Jarama 18"x8" +40 offset BF Goodrich KDW2 225/40/18 Powell Race Shop Trailing Control Arm Bushings Eibach Sportlines Brakes GMPP Cross-drilled/slotted rotors SS Brake Lines OTTP Rear Swaybar Autopower 6 point Roll Cage Autopower Seatbrace Autopower Helmet Hook Go Pro mount on Cage Kidde Fire Extinguisher Mount Future Plans: Coilovers, Sparco Seats, S257ftw now for crappy cell phone pics Attachment 11293 https://i1281.photobucket.com/albums...pszzvrvkr6.jpg Attachment 11294 Attachment 11295 Attachment 11296 Attachment 11297 Attachment 11292 Attachment 11299 Attachment 11300 Attachment 11301 Thanks for looking! |
Very nice sir. Love that engine work!!!
That engine is CLEAN!!! Makes me want to work on my cobalt
Good stuff Vaughn
Thanks Blake! Lets get your car together so you can post pics too! Im fixing to lose to bolt on LNFs cause they got better pics :) mile long mod list only gets you so far
Nice job getting it together. Your mod list is huge!
Got my vote simply for the work you put into this beast. I gotta say though, I like your car with the black OEM wheels better than the TSW's.
Me too actually, but the 8" wide wheel is better for hook
Love the engine bay pic
Wow. The amount of work you put in this car is amazing. Seems like the mods list never ends.
11+ years of work adding up
Holy shit man how much money did you put into that beast?
what did this thing make for power?! holy christ
My car was built TVS and Spray previously, probably had 7k including the nitrous, fuel system and tvs
This turbo build with the engine rework i have another $10K in Will be dynoed as soon as i get a replacement electric water pump from PRP. Shooting for 600 off spray |
Well replacement water pump ordered so should be able to dyno soon!
Can't wait to see this beast run!
Beautiful ride can't wait for it to hit the dyno
Hell with the dyno, I want to see it make a pass.
I'd second that one as well lol
Well just fixed the EWP setup last week, fixed a couple small leaks (car has about 35ft of an line for various fluids), torqued the mounts again.
Going to direct port my nitrous setup and will be changing the suspension to eliminate some of the squat under launch |
Sweet ass build list! Very curious for dyno numbers and track times. Whats your best guess? Congrats on the win.
Aiming for 600whp off spray
Originally Posted by JapEatr
(Post 7626863)
Im going to be doing some suspension work to help but it still is going to spin hard on the street
Take the front fenders off and run some 335's. Racecar style.
