How do you have your vacuum lines run?
ill try to explain it the best i can
-top of the waste gate to boost controller -boost controller to mani -mani to bottom of waste gate (2 tees in that line 1 for boost gauge and 1 for fuel regulator) -mani to bov -mani to evap -mani to brake |
i wouldn't t off of the wastegate and am iffy on using an im reference for the wastegate although that's probably not your problem
why are you using the top port on the wastegate if you have an mbc also, mani to evap? what? that goes into the throttlebody.. |
what is an mbc? and i just hooked it up by the tags that zzp had on each line
manual boost controller
i was told bottom port on the wg for it, and top is unused unless using ebc idk |
hmmm...i dunno. i found a plumbing supply store that is open till 12 tomorrow so im gonna go there and see if i cant get what i need to make a boost leak tester.
the s252et. thats a 3 inch for the intake side correct? |
the turbo outlet is like 2.25 or 2.5 where you connect your cp to
the compressor housing is 3" where your intake connects |
turbo outlet on it is actually 2.0 just looked at when i ordered my couplers
so i need a 2 inch coupling for a boost leak tester then correct?
the ic piping shouldn't be 2" mine is 2.5 and 3" mix idk what zzp sends with their kits, not sure how boost leak tester works or where you hook it up at
you hook it up to where you put your intake on your turbo. then you put about 20psi or what ever you normally boost at. if it holds its fine if it doesnt you can listen to where its leaking out at. lol i have been doing some research
you hook it up to the compressor housing? wtf lol. that would be 3" if that's where it goes
Originally Posted by 05Slowline
(Post 5874358)
Originally Posted by startingline05
(Post 5873867)
my boost gauge is saying 22hg that is why i am going with the pink spring cause thats what it is rated for. i will have a few days before it comes in so im just gonna keep trying different things. what im thinging is the bov is staying open because i have a leak somewhere.
also i tried something new. when i disconnected the vac line that goes to the bottom of my waste gate the blow off valve closed. is there something that could cause that? |
Originally Posted by busa4
(Post 5877994)
if you disconnected your wastegate vacuum line you just created a vacuum leak. this is why your bov closed because spring pressure in the bov over came the lower vacuum signal to the bov due to the vacuum leak. you do not have a boost/vacuum leak. your bov spring is too light. put a stiffer spring in it or keep adding some shims/washers until the bov no longer stays open at idle.
did u have to use the other spring?
