differences between air to air and air to water
ok so i am about to completey redo my charge piping on my turbo setup, and i have been debating running an air to water intercooler vs my current air to air setup. mainly this car will be doing a lot of long distance top end runs on the autobahn, as well as some track time on the nurenburgring(sp*). i was thinking for this knd of endurance running i might wanna switch over to air to water set up like one of these:http://www.precisionturbo.net/interc...tegory_id=3052
for those who actually understand and are familiar with the difference, can you please explain to me the pro's and cons of both systems for my particular application. thanks jim bump no one?.................... |
Pros:
Will make your intake temps even cooler. Generally provide better horsepower numbers. Cons: Sometimes bulky. You'd have to have a catch can for all the ice. Keeping intake temperatures down only lasts for a while, not meant for long period of time. |
Originally Posted by RollermanDan
(Post 2668735)
Pros:
I'd do the air to air option on your car...hell that's even what's being put on mine due to the class rules. As for my car, hell if I know anymore. I'm just waiting patiently for that phone call saying everything is done come pick it up.
i know that air to air is more reliable over air to water because you dont have to worry about the pump going down and other bullshit. i will find the link. hold up
(Post 2669012)
Originally Posted by ColeJJones
(Post 2669021)
air to liquid can be much more efficient for short runs. If you were doing drag racing events and stuff i'd say go for it because you could put an ice setup in there too. Air to Air, especially front mount (actually v mount is the best) will be by far the best as far as long distace/period of time runs go. You will maintain your intercooling efficiency for a long period of time. Go with air to air.
You stick your hand in 30 degree air its cold. You stick your hand in 30 degree water its really cold. Anyone know anything about conductive heat transfer?
Better yet. Its summer, 70F inside your house. Feels nice. Its winter, 70F inside your house. Feels colder. Anyone know anything about radiation heat transfer? |
look at it this way...the water thats cooling your intake charge in a air to water system can heatsoak after longer exposure to heat, whereas the air thats cooling the intake charge in an air to air system cannot heatsoak as its different air molecules all the time. However, as lewis said above, water is a much better conductor of heat, and can hold more joules of heat energy per gram.
basically, water will yield better intake temps, but will heatsoak after awhile, whereas air will not be quite as good as water, but will never heatsoak |
Originally Posted by cakeeater
(Post 2669045)
Originally Posted by jimbos'ss
(Post 2669470)
define v-mount
Originally Posted by lewisb13
(Post 2669087)
(Post 2669735)
The intercooler is in a diagonal position instead of being perpendicular to the ground. It doesn't always work that well, but in many cases you can increase air flow to the intercooler and radiator, have better airflow characteristics, lesss piping, etc. Usually pretty expensive tho because you can't jus tach it on the front.
aaaannnnndddd what's your point? |
(Post 2670098)
See hunterkillers post right below mine.
If you want better results go with a better Air to Air setup... ie: better core... might cost you a lot more money but you will see 100x better results than running some of these other Air to Air setups which are out there....
-Karo |
btw good luck with getting that 30* water LOL
(Post 2787817)
-Karo |
You are all rookies. Conductive heat trasfer of air is .025 W/m*K. Liquid water's conductive heat transer is .6 W/m*K. Thats right, a water-air heat exchanger will HEAT EXCHANGE 24 times better than air to air, but what does the mechanical engineer know? Why do you think they dont use air-air for your engine cooling system? You wanna argue with me about heat soak? Ill ask you again, why dont they use air/air for the engine's coolant system?
no need to get angry...and who is this even directed to? isnt everyone agreeing with us...?
No everyone is saying to go air/air.
(Post 2668794)
ok so air to air is definately better for my application. thanks dan, btw how's the car coming?
(Post 2790180)
We all have to realize that neither system is perfect, and both have their disadvantages. Many time it's all about preference. Although, i will comment on the engine cooling part... water to air does a far better job of keeping the motor more consistent as far as cooling, resulting in better engine efficiency. IMO, they are two different systems (engine coolant, IC coolant), as one regulates heat, the other is intended to provide maximum cooling. |
(Post 2790180)
(Post 2790448)
lol you are so cocky with your mechanical engineering degree. How many times have you brought that up, oversimplified things, then gotten proven wrong? I am giving you the facts...you can think about why. If you can't figure it out after thinking about it i will explain, but a air/liquid intercooler is better for short periods of time. Air to air is better for long period...of course this is with comparable systems.
As a matter of fact the air/water intercooler would highly outperform an air/air over any given time. 3 seconds or 3 days with the exact same surface area for cooling. I.E. you have a water/air with 500 cm^3 of surface area and you have air/air with 500cm^3 of surface area. The water/air >>>>> air/air in any situation. I cant think of one single instance where the air/air would be better. Please dont say, "well why are all the turbo cars air/air from the factory?" Its cheaper, simpler (no pumps, wiring ect), and does a good enough job. Sorry if im coming off as a dick, but I am having a bad day and I dont want people going around looking like idiots. Lets say you heatsoak the media inside the air/air and heat the air up to 500degrees. Then you heat soak the media inside a water/air to 500 degrees. The air/water will cool faster, even though you just heat soaked the SHIT out of it. |
(Post 2790466)
I disagree. And gave you the science to prove it.
You think the water in a water/air HE would be hotter than intake air after a turbo even thought the water/air in closed loop for the water/air and open loop for the air/air? :wtf:
