Exhaust manifold bolt torque specs
I have a repair manual that shows that 112 inch lbs are all that is required to torque the bolts down on the exhaust manifold, that's not really that right at all. I have a 2008 t/c and I am doing a turbo replacement right now, I just think it require more torque than just 10 foot pounds?
That's what the GM service manual says as well. I haven't had any leaks. I also tightened in the correct sequence.
Originally Posted by 1Panel2NV
(Post 7360276)
(Post 7360276)
1 Attachment(s)
Here is the sequence. I forgot about tightening a second time. It will pull down a bit more.
Attachment 21902 |
mine was good for the first month or so. zzp cast manifold and gasket. then started the most faint annoyance
Originally Posted by i944scania
(Post 7368599)
Originally Posted by Darkfuzion
(Post 7369461)
Do you think the torque specs are too low?
You don't want to over tighten or you will have a bad day. Stick with what the book says. |
Good info right here. I need to install my header next week.
i guess i didnt follow the exact pattern according to the book. but i did a cross pattern
(Post 7360598)
http://i121.photobucket.com/albums/o...ps47e7978d.jpg |
Originally Posted by boostbalt
(Post 7437953)
Where can I buy that manual! :)
(Post 7438579)
It's the GM service manual. I was going to say ebay, but the prices there seem sketchy. CED has them for less. If you do try ebay, there should be three volumes.
