briank6102 |
05-07-2012 12:22 AM |
M62 sc!
So hey guys I have a problem you might be able to help with.. I'm rebuilding my m62 sc and I bought the needle bearings from zzp but I can't get the old ones out!! Is there a trick cause they are open back bearings so I can't just use a grease gun and zerks fittings.. I rented a pilot bearing puller from oreilys but still won't come out!! Help please! I'm sure someone has changed these.. I'm thinking about milling them out with a end mill bit at work.. If there's a easier way enlighten me!!
