Quick question for those running meth with a tank in trunk
What route are you using for your hose? Looks like most are drilling a hole in the trunk and then going down the frame rail underneath the car but was wondering if there were any other routes that don't involve drilling a hole.
. Run it out of the.car with wire loom, ive ran a **** ton of setups, and when its inside the hoses seem to get pinched and.etc. run it the same route the battery breather line is and under the car use wire loom tocover it. The. use zip ties or somthing else to keep it up.
