supercharger making loud noises at idle!
Ok guys how hard is it to take of the blower? AT idle the eaton is really loud and noisy and its getting annoying. Someone on the srtforums told me that hes pretty sure that i have a bad coupler and i think he might be right. I pop the hood and watch the belt spin and the the tensior and the belt on the s/c looks loose as shit. Is the bad cupler my issue as o dont want to get a new blower as i found a deal on another one if i have to.
You just have to remove the belt and 4 bolts for the SC....
Originally Posted by IonNinja
(Post 4020075)
what does a coupler have to do with your blower or tensioner? a coupler is the rubberish piece that holds your intake together.
also the SC is very easy to get off...but good luck getting the belt on :lol: The coupler is inside the supercharger, It transfers motion from the shaft to the rotors... Please refrain from giving advice if youre not entirely sure what your talking about. Also, what type of noise is it? Squeaking or like marbles in a can type of thing? |
(Post 4020075)
also the SC is very easy to get off...but good luck getting the belt on :lol: You mention that belt, lol. Hearing of the belt issue scared me so much that I got the pulley boys tension relief tool and the LSJ engine lift bracket (for the tension relief tool to work) so that should be a snap now! |
[QUOTE=IonNinja;4022183]yes I am...and I was entirely sure what I was talking about. :lol: I just happened to be wrong... :lol:
coupler http://www.hawaiiracing.com/shop_ima...a4c47a496f.jpg Couplers are used for many things.... |
sooo waht your saying is the coupler in my supercharger is bad if it sounds like marbles in a can at idle...beacuse mine does that and itll go away randomly too... sounds like shit when it happens tho, is it bad that its been like that for a while now, and is it hard to replace the coupler by yourself??
Originally Posted by Champ_
(Post 4022199)
i'll go ahead and delete my posts now :cool: |
my car at idles sometijmes sounds like a can of marbles, is this the coupler??? also is this bad if its been happing for about a year now?? , and is this hard to change??
i had the same problem and it was my belt tensioner. The tensioner is the shock like object that keeps the belt tight, if you can wiggle it its bad.
there are tones of problems lol... posssable causes... timing chain tensinor( has a technical service bullitin out on this), belt tensinor, S/C coupler(internal) not hard to change... make sure u get some sc oil because at least on my gtp i lost some.( good idea to change while ur in there anyhow)
(Post 4022209)
yes I found that out after a short google search lol
i'll go ahead and delete my posts now :cool: I forget about the whole internet / sarcasm boundaries.. :lol: |
check the oil
How much does the coupler replacement usually cost on these superchargers?
Originally Posted by jthomas9
(Post 4232369)
(Post 4232369)
https://www.zzperformance.com/cobalt...=813&catid=143 https://www.zzperformance.com/cobalt...ts1.php?id=841 shouldnt take more than 30 mins to do the swap...good luck... |
[QUOTE=Champ_;4022199]
(Post 4022183)
coupler http://www.hawaiiracing.com/shop_ima...a4c47a496f.jpg Couplers are used for many things.... Yes its cheap to do the maintenance on the SC and not hard. wow zzp's kit is very cheap. Magnuson also is the only Eaton blower certified repairer and sells a kit as well. |
Is it bad if I do not fix this problem? I bought my 06 cobalt ss/sc used from carmax w/ there warranty. I will check to see if its covered then I will have it repaired, if not then I will jus wait it out until I get more cash. I am a colleg student & I do not have much time to really get involved in my cobalt like I really want. Plus I want to get a new head unit from pioneer before I start changing anything under the hood. I appreciate the help.
Will the dealership not cover it under the warranty?
(Post 4233391)
Use some common sense man. You can end up needing to spend hundreds on a new supercharger.... |
eaton supercharger
Originally Posted by JHans5774
(Post 4281146)
okay the supercharger apart is dumb easy. Its a few bolts and thats basically it. The rotors int he casing have a roller bearing design in the back and the front where the coupler meshes with the rotor gears has bearings. You would be suprised what the coupler will do when it looks good but is not. But take the rotors out look at them for contact check the casing for contact if either exist wither brearings are bad or the supercharger its self may be bad depending on the extent of the damage. My advise either pull it apart and inspect it or run it till it blows and put a turbo on it.
