TIPS FOR A TVS 300+HP BUILD dd
Im currently deployed, so im still doin my fair share of reading and shopping around. im set on getting the TVS. there are just so many different supporting mods. trying to keep the build under 5g's. im pretty sure i need 60lb injectors for 20psi, correct me if im wrong. now which is better for cooling. getting a dual pass end plate or a secondary front mount intercooler. i also dont want to deal with the maintenance of meth injection. how much would it help to get the LS4 throttle body? i was also looking to get either the stage 1 or stage 2 head from j body performance. but recently ive been seeing some not to great comments on them. any advise on them or a head. getting all this done, will i have to worry about my pistons? finally last, anyone in the So Cal area know where to get a good tune for all these goodies, and how much does a tune and dyno run cost.
any advise is appreciated. hell ill even take the newbe jokes
where do i get a custom port and polish. and how much? i seen SMG is still working out the final details on doin pnp at their shop. i was trying to find a package deal. cause i have no idea on how do assemble a head.
^^ yep. I did over 300 with zzp header/dp (stock catback), injen intake, bigger heat exchanger, dual-pass w/ opt b, and a tvs w/ 2.9 inch pulley
Edit: You could check the official dyno thread, it lists what mods everyone has
GRABBER BLUE MUSTANG GT
Save the money and just go turbo. You love the power band, sounds, and will not need all those other cooling mods. 60s, decent turbo, intercooler, and a few other small misc parts will easily have u running over 300 hp for cheaper.I made over 300 with a down pipe and a tune.....
il be doing this next month without TVS, iv got a FULLY ported n polished head with ferrea valvetrain not some of this sanded only crap iv seen for $400. I had http://headgamesmotorworks.net/ do my head work. and im sure i will be braking 300whp. im at 270whp and will be adding a 2.7 and ottp dual pass with the head.
My set up I put down 300/256 on a "conservative tune"
11.2 AFR 20* of timing 50/50 Meth Mix
TVS with 3.1
60's
3" catless downpipe
2.5" magnaflow catback
K&N Intake
LSJ Throttle Body
STOCK GM Exhaust manifold.
No porting or anything.
You're an *******.
TVS with 3.1
60's
3" catless downpipe
K&N Intake
LSJ Throttle Body
it really isn't cheaper hence why I went supercharged with everything borrowed from the SS. If you already have a turbo, manifold, piping, intercooler, injectors, and all the other supporting parts then of course it's cheaper to bolt on a DP and tune to make 300hp. YOU WILL STILL NEED COOLING MODS! just an air to air intercooler will work but you could make more power, safer, and longer if you added meth or nitrous.
as for loving turbo more than super I beg to differ. An eaton supercharger at 7000 rpms sounds like my gf when I really pound her. A turbo sounds like you have an exhaust leak somewhere untill it the turbo starts to go out then it will start whining like a supercharger lol (by go out I mean the bearings once you start to overboost, starve it of oil etc...) superchargers don't have to really worry about oil, or much of the maintanence a turbo car requires.
But the exhaust portion is simplier.
And i like the sound of a turbo and think they are better on higher revving engines.
