Forced Induction Turbos/Superchargers
turbosmart manual boost controller tee questions
Old Jun 7, 2012 | 10:05 AM
07LSJ's Avatar
i got a turbosmart boost controller. the tee one. what im trying to know is, how many turns on the knob is equal to 1 psi? i have the s20g turbo and the wastegate is 16 lbs so im trying to boost a little more. trying to get it to around 20-22. i just have no idea how much is 1 psi and i dont wanna start playing with it without knowing what im doing.
also, if i manualy raise the boost, would i need a retune or would it affect my tune in any way?
Old Jun 7, 2012 | 10:10 AM
Dart_SI's Avatar
Its a lot. My wga is 15 psi and I think it took like 25 cranks to get to 25 psi. Lol. Your best bet is to go do a pull, look at your boost, then adjust accordingly.
And your tune will be fine. I drive on 24psi usually and turn it up to 28 for "fun time" just keep an eye on that boost gauge, especially after a good temperature change. I was boosting 24 psi one day and the next day it was 27 because it was like 40* colder out.
Old Jun 7, 2012 | 10:12 AM
07LSJ's Avatar
i was thinking maybe each full turn was 1psi. i guess ill have to do like you said.
does that change my A/F ratios a lot?
Old Jun 7, 2012 | 10:20 AM
Dart_SI's Avatar
No. Your car will adjust for any boost level. Just don't crank up the boost too much. Idle what's safe for a 20g but on my BNR I wont go past 28-29 psi. After that its just blowing hot air. And no 1 turn isn't 1 psi. Lol. If I tried that boom.
Just start off with 5 clicks, monitor the change in boost (say 15 psi before and 17 after 5 clicks, then just click it over like 15 times and toil be around 23-24. Just an example.
Old Jun 7, 2012 | 10:27 AM
07LSJ's Avatar
yea i feel you. thanks man! imma try it on saturday and finally finish my tune. hopefully the car will be runnnng perfect.
Old Jun 7, 2012 | 10:56 AM
rivaladore's Avatar
Really? Say the op is tuned for 20psi, it's ok for him to increase it a couple psi without a retune? I was always under the assumption that you would start running lean. I might have to crank up the boost just a little bit if that's the case.
Old Jun 7, 2012 | 11:02 AM
Dart_SI's Avatar
From my understanding youll be fine. The MAF will read the extra air an adjust everything accordingly. If it sees more air (more boost) it will add more fuel and keep your WOT afr on target.
Im not a tuner tho so id get a second opinion from someone who tunes just in case.
Old Jun 7, 2012 | 11:04 AM
07LSJ's Avatar
yea i think my tuner said just that. that the car will adjust to my A/F ratios accordringly. anyways, im going to be checking them when i raise the boost just in case.
Old Jun 7, 2012 | 11:07 AM
jonathan923's Avatar
if your tuned on 16psi and your going for much higher boost levels such as 22psi+ you deff need a tune or else the car is just going to run straight lean and then boom. better be safe than sorry.
Old Jun 7, 2012 | 11:12 AM
07LSJ's Avatar
lol ill just do it at the same time joe tunes me. to be safe
Old Jun 7, 2012 | 11:13 AM
Dart_SI's Avatar
Makes sense. So a few psi should be ok.
brandon04
Oct 21, 2015 07:04 AM
OrangeCoba
Oct 1, 2015 10:00 PM
Extremespeed
Sep 29, 2015 04:34 AM
Sep 27, 2015 08:53 PM
