Type of spark plugs
Hey guys, I currently own a 09 Cobalt ss turbo with the trifecta tune running @ 23psi. My question to you guys is what type of sparks plugs have been the best for yall running with this setup? My car seems to running a bit rough @ idle, but when I got the car I replaced the plugs with some 1 step colder ones, i dont think my car likes them very much bc sometimes it will misfire when WOT going into 2nd.
So what do you guys think? Im new with this whole turbo thing but I am eager to learn. Ive had the car since Nov, 2011. |
stick with stock plugs from the stealership. i had the same problem when i switched my plugs. oem plugs work the best in the lnf's from what ive been told
Stock plugs and stock gap. Don't buy them from the dealer.
stock plugs. mine are stock gapped to .032 and i have no issues
i concur with the above^^
What brand are stock plugs? Autolite?
Originally Posted by Chevy_tuner
(Post 7081354)
Originally Posted by Cman46290
(Post 7081374)
AC Delco
Thank you
can't you get the NGK brand name as well, as its the same? Not sure of all part stores have the ac delco or which one will be more expensive.
Originally Posted by northvibe
(Post 7081478)
When I went to auto parts stores I couldn't find the ac delco version I think. Rock auto had both and ac delco was cheaper.
Originally Posted by emiller
(Post 7081510)
Originally Posted by Terminator2
(Post 7081505)
IIRC NGK versions are not pregapped and cost a couple bucks more a plug. I recommend only OEM AC Delco plugs and gap depends on the setup but on a bolted and tuned stock turbo car 0.032" works well. Big turbo cars on high boost need to squeeze the gap down to 0.026-0.028".
(Post 7081602)
Oh, I thought NGK came pre-gapped.
(Post 7081609)
I believe they do come pregapped but to 0.045" not 0.035".
I need new plugs for my white slut..... Better call tom. |
