fuel smell coming from car
so for the past couple of months i have been smelling a hint of gasoline after any drive, i have gotten underneath the vehicle, looked under the hood, filling cap, and by the gas tank to try and find where the smell is coming from but i have had no luck. i think this is killing my gas mileage because after short drives my gas level drops quite a bit. Im just wondering if any one else is having this issue as well and where else i can check so i can find this smell.
Thanks in advance:cssNET: |
your first suspicion of a leak is probably right. I don't know of the name of the product, but I think they sell fuel leak detector kits which is basically a dye that will glow under a florescent light in the presence of fuel. Be careful of fuel leaks as they can be dangerous. Take it to a shop if need be.
does your call fall in the recall for the fuel hose that cracks and is covered under warranty. the dealership replaces the whole fuel pump free of charge. 06-08 cobalts and hhr i believe. also a power steering recall for those same years. maybe check into that if you havent had it done and havent solved the fuel smell. im sure you have by now i realize this post is 4 months old.
Fuel line leak on the top of the tank
Originally Posted by weakyota91
(Post 5460852)
