How many miles do you get on a tank?
I got a 2009 cobalt... auto...AC. Stock car
I drive 75% highway @ 60mph and 25% city. At 530km (330miles) my low fuel light comes on ... and I typically hit the pump at 545km (339miles)... I dont use my AC.
Is this typical?
It has me wondering, because my 2003 cavalier with an ecotec would go 600-650km (372 - 403 miles) per tank with the same route to work. Although it was 5-speed std.
Just curious
Thanks
Sorry ... my cobalt is an LS ( NO turbo and NO bigger motor)
Is this typical?
Just curious
Thanks
I run about 625 km on a tank but I am >90% highway. Low fuel has come on maybe 50% of the time when I fill it.
BTW, miles per tank means nada unless you are comparing cars with identical tanks - same make / model for the most part.
Your cavy had a 15.2 gallon tank, your balt has a 13.9 gallon tank. If they both got the same mpg you would go farther on a tank in the cavy but I would hazard a guess you get better economy out of the balt even if it is an automatic
90% highway,
at 55-60mph, temps above 50 degrees, 34 mpg.
23 mpg city
90% highway at temps below 50 degrees, at 55-60 mph, 29 mpg
90% highway at 80+ mph: 25 mpg.
23 mpg city
Haz l33t wheelz.
Keep in mind I pay almost $10/fillup less than everybody else. Makes the freakout so much less severe. Then again I used to get 41mpg highway out of her with just the intake and exhaust on, so it's a bit of an adjustment. I run the calculation and get back 20mpg and I just about jump out of the car to do a happy dance in the middle of the gas station.
