Hypermiling
I never understand they say to brake softly to save gas. How does braking use gas? Or do they mean if you brake you will eventually have to accelerate again and that is where you use more gas?
Anyone?
Anyone?
I guess it means the less you slow down the less you have to speed up. For example, if your coming up on a red light, instead of speeding up to it and then hitting your brakes (slowing down a lot) and then immeadiatly taking off again, you slowly coast from a distance so that when it turns green youl still be going somewhat fast and not have to use as much gas to get up to speed. It will also save your brake pads.
The other downside I've read and it would be obvious to most people is that if you overinflate your tires, you will get uneven treadwear. So yes, you save money on gas, but what about tires...
The trick i used when i can is pop it into neutral when i am going down hill and can coast with out loseing speed or when coming up to a stoplight/sign. Just doing those things brought me from 26-28 in town to consistant 30-31mpg.
putting it in neutral is worse than leaving it in gear. when you leave the car in gear and are off the gas you are getting better gas mileage than coasting in neutral. you got better gas mileage because you were trying to. and i guarantee that if you leave it in gear and coast, you will get even better mileage than you do now.
it's actually illegal in some states to coast in N on hills.. but the problem with this technique is the ******** behind you blowing their horn or arrogantly passing you cause your not getting to the light fast enough for them which really pisses me off...
Injectors only close coming from a higher rev range so say you are revving down from 3k, yeah, until about 1.5k the inj open again.
Then you pop it into neutral.
Mix of both FTW
Original Hayden Fanatic
its pretty easy to get good milage. but the people that shut off there cars when driving are nothing more the grade A *******. When a 2.2L cobalt or a Fit or any other small car can be driven to near hybrid levels then something is wrong.
there are the standard ways to save gas, drive slower, keep your speed (stop less), check your PSI in your tires, remove the "junk in the trunk", don't run A/C unless you HAVE to, keep windows up or crack them when driving, etc. etc. Then there are the "frog hairs" and extremes, getting a thinner oil, narrow tires, replace glass, carbon fiber bits, lighter wheels, lowering, tape the joints of the car/make it slicker, keep the car clean and smooth, ECU work, intake and exhaust, etc. etc.
Basically just conserve your kinetic energy as much as possible to obtain higher energy efficiency.
You get better gas mileage when coasting IN gear then when in Nuetral. While in gear your car will actually shut off the injectors and use kinetic energy to keep the car running. When you put the car in Nuetral the car has to keep the injectors flowing so the car doesn't die. Fuel cutoff settings for the coblat are I believe: Fuel cutoff turns on at above 36 mph and 1750 rpms (which means fuel cut off will be enabled if you take your foot off the gas. Have you ever noticed that when you take your foot off the gas the car kind of jerks? This is fuel cut off at work.) and turns off (injectors start flowing again) at under 18 mph and under 1250 rpms. Those might be a little off I would have to check the setting in HPTuners again to verify, but they are close enough.
You have to understand when i do this i mean on a hill or i am usually over the speed limit anyways I don't hold up traffic because nothing gets my blood boiling quicker than some ******* going under the speed limit, especially in the fast lane or when you get 2 side by side The places i do it you usually accelerate when in N cuz of the down hill anyways. How are the cops going to tell if i am in Neutral or gear? I have a 5 speed and my windows are tinted, there is no way they can tell.
neutral costing is retarded, dangerous, stupid, not to mention illegal in many places.
it also uses MORE gas than downshifting properly
whoever taught you to do it, please slap them in the head.
if you dont believe me, google something called "Decelleration Fuel Cut Off"
? How is that going to happen? I have a manual, its not like the shifter can just be bumped into Reverse.
Anyways i just research some of this stuff, i guess i will go back to what i was doing (not coasting or anything) and see if there is a difference.
no. neutral costing.
whatever.
you kids know best. im sick of arguing this one over and over. its been done many times.
whoever taught all you kids to drive should be ashamed.
******* pathetic.
whatever.
******* pathetic.
