LDK Opel Injectors
LDK Opel Injectors
Last July I swapped a full LDK in my sedan. LDK came with everything on it (turbo, coil packs, intake mani, injectors, etc) So I was told this LDK had the opel injectors. My tuner said from looking at my data logs my car does not have the opel injectors. I know everyone is gonna say just pull off the intake mani and pull them out and look. I plan on pulling the intake mani this weekend now that the weather is going to be decently warm. So my question is, is there any way to tell without physically pulling the intake mani off? Also if I do pull the intake mani off do I physically have to pull out the injectors or will I be able to look at a part number on them and know?
LDK engines had LNF injectors and white seals. LHU engines had OPELS and black seals (this is the reason I went LHU for my engine swap). if your tuner knows what theyre doing and they say you have stock injectors id say you have stock injectors. when I did my swap, for kicks I left my injector settings alone and did a datalog and my trims were all wonky, pulling lots of fuel. when I changed my injector constant from .028xxx to .025xxx my trims were much closer.
you might be able to get under the car and pull the foam away from the fuel rail to get the part number that's on them. they'll look the same other than the part number stamped on them. here's a pic of my LNF injector (fuel rail end) I took when I did the seals on my car, a month before the engine blew.
Don't remove the Opel injector from the rail if at all possible. There's a little straw type tip on the end, like above the blue o-ring in the injector in the pic on the Opel's. They break very easy. Guess its anyone's guess if a new Opel injector/rail assembly has tips already broken inside or not. I was very careful pulling mine out and they still were broke. Don't know if I did it or not. There's a bit of a debate as to whether it makes a difference or not . ZZP says it may cause high RPM misfires. Some say it doesn't. Strange thing is the LNF injectors have no such tips.
I bought it off mongo and he states they are the same opels ZZP sells. Which ZZP site states they flow more. Mongo told me he used they on his car with e85.
my tuner is KMO43 which im sure he will chime in soon and state that my logs were spot and on.
From all this I am gathering that they are NOT the ones that flow more but I do imagine the seals are e85.
Wonder what I have then.
ZZP sent me the engine, but some how didn't know what was in it.
Matt went to tune me for it, after putting it in, and asked me what injectors it had in it.
Asked me to call the mechanic putting it in, to see if it came with injectors.
The engine they sent had injectors, so he said it must be the opal then.
So, really I have no clue what's in there for sure...
For some reason I thought the people selling me the product would, but I guess that was just silly of me.
