Beware of tin foil on OIL
Old Apr 5, 2014 | 04:40 PM
impalaboy327's Avatar
Changing the oil today and apparently a piece of the tin foil, about a dime size, fell into the oil and I saw it pour right down into the oil fill. Small enough piece that I am not too concerned about it, just a heads up. Hope it will a. get chewed up and end up in filter or b. lodge in a corner somewhere or c. come out in next oil change. FREAKING MOBILE 1.
Old Apr 5, 2014 | 04:45 PM
andrewcarr1993's Avatar
That's definitely something to worry about not to just ignore. That's enough to clog a line and starve a part of the engine of oil although I believe the pick up does have a mesh screen it wouldn't get past, but at teh same time it was pored into the engine from the valve cover so I kinda doubt it got all the way to the oil pan.
Old Apr 5, 2014 | 05:02 PM
Xmetalhead2003X's Avatar
Probably should have cleaned the foil off better on the bottle neck. Don't have to worry about that with mine. Amsoil ftw.
Old Apr 5, 2014 | 05:08 PM
I pull it completely off the bottle before I poor it, Royal Purple.
Old Apr 5, 2014 | 05:20 PM
buildmeanempire's Avatar
Does your cap say oil and tin foil? NO! Drain that **** and change it.
2 to 1 odds that a my engine blew thread pops up in two weeks
Old Apr 7, 2014 | 12:04 PM
Stumpalump's Avatar
Don't sweat it.
Old Apr 7, 2014 | 12:11 PM
Kyle09TC's Avatar
i would most definitely be either:
A) draining the oil and pouring oil through hoping it comes out, or
B) dropping the oil pan and hope that it got caught in the screen
Old Apr 7, 2014 | 12:23 PM
phatnackySS's Avatar
this is why engines have oil screens and filters. I wouldn't worry about it
Old Apr 7, 2014 | 12:24 PM
BlackielawlessSS's Avatar
Le boom time..
Old Apr 7, 2014 | 12:56 PM
Staged07SS's Avatar
Administrator
Administrator
It's not mobil 1's fault you dropped the foil in your engine....
I always carefully remove the foil before I pour the oil in my engine.
I would def at least drain the oil, or remove the cam cover to see if you can find the piece of foil.
Old Apr 7, 2014 | 01:04 PM
Gelladuga69's Avatar
Trying to play it off as that foil was already in there and not from you dropping it in the bottle.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
