Calculate 1/4-Mile E.T. From Horsepower - Horsepower Calculator
I should be running 12s man!
me too. that thing is BS.
How much are you using for weight. Anyone know how on/off the aeroforce hp gauge is. It's flywheel too right? |
put 3000 pounds and 200 wheel horsepower, gives u low 14's which seems right
Based on my time and weight my car makes 188 at the Flywheel
I'm runnin 13.2's lol
Kind of funny how I punch in 240WHP and a weight of 3,200 and I come up with a 13.8? I am assuming your car is about 3,000 and adding 200 for driver. Now these calculators are not 100% but they are usually with in a couple of tenths and don't take into consideration variables such as wheelspin or poor driving. I mean it's just a math calculation based on the power to weight ratio. Hey Asstyme I am from Janesville too;). |
get drag radials and the times would be more realistic in real life as well
i call bs:
Originally Posted by Ricer Calculator
Your Cobalt which weighs about 3100 pounds should complete the 1/4-Mile in about 15.9 seconds, if you can produce about 152.43 HP at the wheels, or about 198.15 HP at the flywheel.
Originally Posted by D4u2s0t
i call bs:
This part of the calculator is based on a rear drive v8 car which will lose about 20% of the horsepower at the crankshaft. Now a front drive manual trans car will only lose about 5-7% of the HP from the crank to the wheel..... so you would only be producing about 160HP at the crank if this formula was set-up for a front drive stick. I guess using one of these calculators means you need to know a little bit about cars....... |
By the way I have no idea how much power your car is rated at stock- my guess is about 160 HP at the crank is about right?
haha... you say it's for people that know about cars, then say a fwd car only has 5-7% loss?? :lol: and it doesn't say anything on that page about it being for a rwd v8 |
It says i should be running 13.55 and I ran a 13.62. Im guessing im pushing 250hp it says im pushing 248. Seems alright to me.
who knows... maybe i'm the idiot! wouldn't be the first, or last time |
i think its a solid guess...
over the weekend with half tank of gas and me in it my car was 3160lbs i put that in and my guestamated(sp?) hp and it gave me 12.6's...so with rob and a few others that i'm on the tuneing/moding level runing 12.80's i'd say this thing is dam close! |
Says this at the bottom of the 1st block... "This calculator esitmates your quarter-mile elapsed time (E.T.) when given the weight of the vehicle and flywheel or "at the wheels" horsepower. A 17% driveline loss is assumed for flywheel HP." I would assume 17% means RWD |
145.
How much does your car weigh with you in it? |
"This calculator esitmates your quarter-mile elapsed time (E.T.) when given the weight of the vehicle and flywheel or "at the wheels" horsepower. A 17% driveline loss is assumed for flywheel HP." I would assume 17% means RWD Yes, 17% is for rear drive- and an automatic will lose more than a stick, a high stall converter will eat a lot too, so will big transmissions such as a turbo 400 verses a turbo 350 and a Dana 60 verses a 10 bolt. You can buy a desktop dyno program that really can dial in on things and predict how changes will affect things. |
"This calculator esitmates your quarter-mile elapsed time (E.T.) when given the weight of the vehicle and flywheel or "at the wheels" horsepower. A 17% driveline loss is assumed for flywheel HP." I would assume 17% means RWD right... but it calculate about a 25% loss... who knows |
" Hey Asstyme I am from Janesville too"
im only a 1/2 hr away |
I hope that calculator is right. With 3000 lbs. and the 271 WHP I dynoed in 4th gear, I got a time of 12.9 and with the 274 WHP I dynoed in 3rd gear I got a time of 12.8. Not bad at all.
With traction and a good run I would think you would be pretty close but don't forget the conditions at the track might be a little different that at the dyno. How did you get the car's weight down to 3000? Hope you get yourself a 12. :) |
