Commonly Used Forum Acronyms
Commonly Used Car Related Acronyms:
ABS - Anti-Lock Brakes ABRS - Air Bag Restraint System AC - Alternating Current A/C - Air Conditioning ADJ - Adjust or Adjustable ADV - Advance AFS - Airflow Sensor A/F - Air/Fuel Ratio AI - Air Injection AIR - Air Injection Reactor AIS - Air Injection System ALT - Alternator or Altitude ALDL - Assembly Line Data Link Amp - Ampere APS - Absolute Pressure Sensor ASDM - Air Bag System Diagnostic Module ASV - Air Suction Valve A/T - Automatic Transmission ATF - Automatic Transmission Fluid ATS - Air Temperature Sensor AWD - All Wheel Drive AUX - Auxiliary AVG - Average BAC - By-Pass Air Control BAP - Barometric Absolute Pressure Sensor BARO - Barometric BATT - Battery BCM - Body Control Module BHP - Brake Horsepower BMAP - Barometric and Manifold Absolute Pressure Sensor B/P - Backpressure BPS - Barometric Pressure Sensor BTU - British Thermal Unit BVSV - Bimetallic Vacuum Switching Valve C - Celsius CAB - Control Arm Bushing CAI - Cold Air Intake CAT - Catalytic Converter CB - Circuit Breaker CC - Cubic Centimeter CCW – Counterclockwise CED – Crate Engine Depot CID - Cubic Inch Displacement CM - Centimeter CMP - Camshaft Position Sensor CO - Carbon Monoxide CO2 - Carbon Dioxide CPU - Central Processing Unit CSSA - Cold Start Spark Advance CSSH - Cold Start Spark Hold CTS - Coolant Temperature Sensor CTS - Catera Touring Sedan [Cadillac brand related] CTVS - Choke Thermal Vacuum Switch CVC - Constant Vacuum Control CVR - Control Vacuum Regulator CW - Clockwise CYL - Cylinder D/P - Downpipe DB - Decibels DC - Direct Current DEFI - Digital Electronic Fuel Injection DERM - Diagnostic Energy Reserve Module DFI - Digital Fuel Injection DFS - Deceleration Fuel Shutoff DIAG - Diagnostic DIC - Driver Information Center DIST - Distribution DLC - Data Link Connector DOHC - Double Overhead Cam DTC - Diagnostic Trouble Code DOT - Department of Transportation DRB-II - Diagnostic Readout Box E85 - Ethanol Fuel Mixture 85% Ethanol + 15% Gasoline EACV - Electronic Air Control Valve EBCM - Electronic Brake Control Module EBM - Electronic Body Module ECA - Electronic Control Assembly ECM - Engine Control Module ECU - Electronic Control Unit EFI - Electronic Fuel Injection EGO - Exhaust Gas Oxygen Sensor EGR - Exhaust Gas Recirculation EGRPS - EGR Valve Position Sensor EGRT - EGR Temperature EI - Electronic Ignition EMI - Electromagnetic Interference EMR - Electronic Module Retard EOS - Exhaust Oxygen Sensor ESC - Electronic Stability Control EVAP - Evaporative Emission System EVIC - Electronic Vehicle Information Center F - Fahrenheit FI - Fuel Injection FWD - Front-Wheel Drive G85 - Limited Slip Differential Option for GM GDI - Gasoline Direct Injection GEN - Generation GND or GRND - Ground GPS - Global Positioning System GVW - Gross Vehicle Weight H20 - Water H/D - Heavy Duty H/E - Heat Exchanger Hg - Mercury HGT - Height HLDT - Headlight HO - High Output HO2S - Heated Oxygen Sensor HP - High Performance or Horsepower HPT - HP Tuners HTR - Heater HZ - Hertz IACV - Idle Air Control Valve IAT - Intake Air Temperature IATS - Intake Air Temperature Sensor IC - Integrated Circuit I/C - Intercooler ICM - Ignition Control Module ICS - Idle Control Solenoid ID - Identification IFI - Indirect Fuel Injection IGN - Ignition IN - Inches INJ - Injector ISC - Idle Speed Control ISO - International Standards Organization ITCS - Ignition Timing Control System ITS - Idle Tracking Switch IVSV - Idle Vacuum Switching Valve KM/H - Kilometers Per Hour KS - Knock Sensor L61 - EcoTec 2.2L pre-2009 Engine LAP - EcoTec 2.2L post-2009 Engine LCD - Liquid Crystal Display L/D - Light Duty LE5 - EcoTec 2.4L Engine LED - Light Emitting Diode LHD - Left-Hand Drive LNF - EcoTec 2.0L Turbocharged Engine LSJ - EcoTec 2.0L Supercharged Engine LSD - Limited-Slip Differential LTFT - Long Term Fuel Trim LWB - Long Wheel-Base MA/MAF - Mass Air Flow MAFS - Mass Air Flow Sensor MAP - Manifold Absolute Pressure MAT - Manifold Air Temperature MFI - Multiport Fuel Injection MIL - Malfunction Indicator Light MPG - Miles Per Gallon MPH - Miles Per Hour MPI - Multi-Point (Fuel) Injection MPV - Multi-Purpose Vehicle NA - Not Available N/A - Naturally Aspirated NOx - Oxides of Nitrogen NVRAM - Nonvolatile Random Access Memory O2 - Oxygen O2S - Oxygen Sensor OBD - On-board Diagnostics OBD I - On-board Diagnostics One OBD II - On-board Diagnostics Two OBD III - On-board Diagnostics Three OC - Oxidation Catalyst OD - Overdrive O.D. - Outside Diameter OE - Original Equipment OEM - Original Equipment Manufacturer OHC - Over Head Camshaft OHV - Over Head Valve O/S - Oversize OS - Oxygen Sensor OTTP - Over The Top Performance Company P/N - Part Number PCM - Powertrain Control Module PCV - Positive Crankcase Ventilation PECV - Power Enrichment Control Valve PFI - Port Fuel Injection PID - Parameter Identification PIP - Profile ignition pick-up PNP - Park Neutral Position Switch PPM - Parts Per Million PROM - Program Read Only Memory (chip) P/S - Power Steering PSI - Pounds Per Square Inch PSP - Power Steering Pressure PSPS - Power Steering Pressure Switch PTC - Pending Trouble Code RABS - Rear Anti-lock Brake System RAC - Remote Accessory Controller RAM - Random Access Memory RCM - Restraint Control Module REC - Receive RECAL - Recalibrate, Recalibration RECIRC - Recirculation REF - Reference RKE - Remote Keyless Entry ROM - Read Only Memory RPD – Reprogrammable Performance Display RPM - Revolutions Per Minute RSC - Roll Stability Control RWD - Rear Wheel Drive S/C - Supercharged SEFI - Sequential Electronic Fuel Injection SES - Service Engine Soon (light) SFI - Sequential (Port) Fuel Injection SIL - Shift Indicator Light SIR - Supplemental Inflatable Restraint SIPS - Side Impact Protection System SOHC - Single Overhead Cam SPFI - Sequential Port Fuel Injection SRI - Short Ram Intake SRS- Supplemental Restraint System SRT - System Readiness Test S.R.T. - Street & Racing Technology STFT - Short Term Fuel Trim STS - Short Throw Shifter TACH - Tachometer TB - Throttle Body TBI - Throttle Body Injection T/C - Turbocharged TCC - Torque Converter Clutch TCM - Transmission or Transaxle Control Module TCS - Traction control solenoid TD - Turbo Diesel TDI - Turbo Direct Injection (A turbo charged direct injected diesel engine) TPS - Throttle Position Sensor/Switch TPT - Throttle Position Transducer TTR – Turbo Tech Racing Company TVS - Thermal Vacuum Switch TWM - TWM Performance Company VAC - Vacuum VIN - Vehicle Identification Number VM - Vacuum Modulator VOLT - Voltage VSS - Vehicle Speed Sensor VSV - Vacuum Switching Valve VTEC - Variable Timing Electronic Control VVC - Variable Valve Control VVT - Variable Valve Timing WOT - Wide Open Throttle ZZP – ZZ Performance Company Other Commonly Used Forum Acronyms: FS - For Sale GLWS - Good Luck With Sale IIRC - If I Recall Correctly IMO/IMHO - In My 'Honest' Opinion TTT - To The Top QFT - Quoted For Truth WTB - Want To Buy |
Sorry but CTS is for Catera Touring Sedan by Cadillac :lol: ;)
Got it
You forgot VTEC
Variable Timing Electronic Control. :)
vtec - whum bummm bummm bahhhhhhh
Very nice! Thread stuck
Added the almighty vtak :lol:
Call me a newb but whats iirc
Originally Posted by reduf99
(Post 6635200)
QFT ^^^^ lol
(quote for truth) |
Added IIRC and IMO/IMHO
Originally Posted by Aleksey
(Post 6635248)
2010 LNF: Pedders, OTTP Rear S/B, Injen H/S, ZZP I/C, K&N SRI, ZZP DP, OTTP Stg2 T/M, Tint 30/15, MPx Shorty
Check out your personal car description. S/B, H/S, I/C, SRI, and T/M are all not listed. :nono: Unless these wouldn't be considered common :lol: Maybe add CAI as well - cold air intake Good thread though. Free bump |
Shit I made up, I honestly forget half of the time what they mean :r: blame the sig maximum character allowance.
Added: D/P, CAI, SRI, H/E, I/C |
hi Aleksey!
Thanks for sharing. |
#cobatlanguage
PIITB
put it in the boot. and cts stands for compact touring sedan. caddy didnt want anyone thinking of the shite catera when they made the cts. that dude was a tard. |
What's gsm1
What's gsm1
General motors stage one upgrade for the lnf cobalt. It sa factory installed modification which includes a 3bar map sensor and a tune to produce more power
Very helpful actually. Lol
So many threads buried and actually pretty helpful
